Question about Microwave Ovens
Installing a fuse in a GE spacemaker jvm130g microwave
Model has been discontinued
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 18, 2008
vitg55
  • 78 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
SOURCE: need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Posted on Apr 09, 2009
What model replaced the 36" profile spacemaker?
I am under the understanding that GE and other manufactures have discontinued the 36" microwaves you may have to purchase a trim kit to fill the space from a 30" unit.
Sep 22, 2014 | GE Profile Spacemaker Over-the-Range...
HI - our rotating plate cracked for a JVM1450BA001 micro. Do have a replacement part for this model? I believe it has been discontinued.
Even though the model has been discontinued, the tray is still available. If you go to www.appliancepartspros.com and enter the model number you should be able to find the tray there. Hope this helps you.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker Model JVM130G 002 (Date 1989) and the handle is broke. Does anyone know the part number of the handle replacement?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Looking for GE microwave handle. Coast appliance discontinued it. Part # FR-5303912615
The part number you show is not a GE part number.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turns on but does not heat
if your microwave does not heat up when turned on its maybe the coil is burnt out are fuse broken, so check your dealers
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Aug 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Model JVM130G
what brand is this and did the light go on when the door was opened before you changed the bulb?
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
