Question about Dishwashers
The LG ldf6810st dishwasher doesn't turn on. We barely use it even though its about four years old.
  • 4 Answers
Buy a new one
Posted on Dec 12, 2012
SOURCE: LG Dishwasher Model LDF6810ST Dishwasher won't turn on
your model probably has a coating of a black tar-like substance on the inside of the inner door, which, by design, reduces noise. However, LG failed to notice the corrosive properties of the black tar-like layer. Your wiring harness is probably corroded by the soundproofing, and you will need a new inner door, wiring harness, and circuit board. LG extended my parts warranty because they know it's their fault, Call them at 1-800-243-0000. They will recommend an LG warranty repair certified technician in your area to come out and confirm this. They probably won't extend the warranty until after the tech checks out ur unit. However, labor will be your responsibility.
Posted on Dec 27, 2008
onthejob5130
  • 640 Answers
SOURCE: LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Posted on Feb 04, 2009
  • 423 Answers
SOURCE: LG LDF6810ST Won't Turn ON
If you are still having the problems you describe and especially is you are getting a leak from the lower left door panel, please provide the model number and the serial number.
There IS help available if you provide the info.
Please report back. Thanks!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: LG LDF6810ST dishwasher
Steps to fix OE are as follows:
-Check the Drain Hose is not kinked or blocked.
-Are all wiring connections OK?
-The drain outlet of sump is blocked.
-The Drain Pump/Motor or circuit has failed.
To check the pump motor: -Measure the electric resistance of Drain Motor. (best between 20-40 ohms) If out of range, replace the Drain Motor or repair the Circuit.
Good Luck! Please report back your findings.
  • 423 Answers
SOURCE: Have a 2+year old LG LDF6810ST dishwasher that
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Posted on Aug 12, 2009
What is the Thermistor on my LG Dishwasher LDF6810ST?
It is the Sensor attached to the Water heating compartment (Element) on the Dishwasher.
It is attached to the Circulation pump.
See below image (It is the part in BLUE)
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 08, 2011 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher makes a buzzing noise and then shuts itself off.
MINE IS A 3850DD3006A AND IS 4 YEARS OLD. I HAVE CHANGE THE MOTOR TWICE FOR THE SAME PROBLEM, IT GIVES CODE LE. THE MOTOR RING SPLITS AND WON'T LET THE MOTOR SPIN EASILY.
WHAT A PEACE OF JUNK!!
Nov 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
NO HOT WATER
it has a hot water element that can burn out
have it checked by an electrician or technician
Sep 11, 2017 | LG LDF6810ST Stainless Steel Built-in...
Info on replacing seal on LG model LDF6810ST dishwasher
Hi, Jus replaced a door seal for my sister in law... very simple.. just pull out the old one, soak the new one and push it in place...15 minutes tops...
Here is a tip that I wrote about leaking dishwashers
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Apr 22, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Dishwasher - LE Error
If this LG LFD6810 dishwasher is less than 24 months old, the parts are still covered, just not the labor.
Recommend you contact LG service and discuss your failed wash motor.
And yes, because the impeller (and the motor it is connected to) does not spin freely, it is the culprit.
Good Luck!
Apr 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishes do not come out clean?
is the salt container cap damaged or loose? is the rinse aid topped up? if all ok then are you scraping most of the food from the plates, this can cause old food to mush, pulp and leave grit on dishes.
Mar 18, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
Aug 17, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
