Question about LG 47lm6700 47 3d Led 120hz Smart Tv Cinema
Picture has horizontal lines - LG 47lm6700 47 3d Led 120hz Smart Tv Cinema
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Horizontal lines while taking picture
i also get horizontal lines on pictures taken...it was never like this before until only when i use this today...i have not been using this for 3 w weeks now and i never dropped it either....
Dec 16, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Aug 03, 2009 | Canon PowerShot A430 Digital Camera
HORIZONTAL LINES WHEN i TAKE PICTURES WHY AND HOW TO GET RID OF THEM?
horizontal lines when i take pictures on optio m10 dont know why or how to fix!!!!
May 02, 2009 | Pentax Optio M10 Digital Camera
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Horizontal LINES
If you are getting fine horizontal lines thet means the picture is over exposing. most probably the apparture or the shutter blade mechanism is not working fine. needs repairs.
Jan 19, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
LG 47lm6700 47 3d Led 120hz Smart Tv Cinema Logo
60 people viewed this question
Computer Repairing
Computer Repairing
