Question about Westinghouse Refrigerators
Westinghouse RJ532S-R how to remove cover of lamp inside fridge?
Want to replace light bulb but don't want to damage cover when removing.
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
woodchuck789
  • 4070 Answers
SOURCE: My fridge whirlpool gold side
When the water filter is stopped up it will bypass to the drain pan.
Posted on Aug 26, 2010
  • 842 Answers
SOURCE: westinghouse freestyle fridge rj532s-r is
You have an obstructed drain in the freezer or within the drain tube itself. You may have to thaw the unit to fix the problem, but it not terminal and you should not need parts, just need to locate why the water is collecting and clear the tube.
Good Luck
Posted on Sep 23, 2011
emissionwiz
  • 79865 Answers
SOURCE: I need a wiring diagram for the RJ532S freestyle westinghouse fridge. The defrost timer is dead and its in defrost mode
We do not have wiring diagrams. Please contact the manufatuer for a service manual
Posted on Feb 02, 2012
  • 884 Answers
SOURCE: how do i replace light bulb in whirlpool fridge freezer
It has plastic lugs that fit into the housing. carefully prise the moulding off and the lamp is right there.
Posted on Apr 26, 2012
Where i bulb located on a mitsubishi wd 62525 rear progection hd tv?
Through the front of the TV. Remove the speaker grille (IT SNAPS OFF & ON) & there is a lamp cover with 3 screws holding it in place, near the left speaker.
That lamp part#: 915P020010 $49.00 TO $100.00
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-62525
Jun 03, 2014 | Philips 60PP9202 60" Rear Projection...
Silhouette manual
I am guessing you want to replace the bulb! Remove plastic cover which can be held in place by philips head screw or screws. The plastic cover can have side clips that need to be squeezed in gently to allow them to release from a slot in the fridge. Once the cover is removed, the bulb should be a screw type. Remove and then buy a replacement - the edison screw size and wattage are the most important thing to fit. Bulb shape to suit size behind the cover. Buy at WW or Coles otherwise spare parts on possibly ebay if you can be precise on model etc.
Jan 17, 2014 | Westinghouse Refrigerators
Westinghouse Aurora RJ442 how to remove the cover of the light inside the fridge?
A flat driver between the plastic cover and the fitting will lift the edge. Gently pull outwards and the tabs come out
Apr 27, 2012 | Refrigerators
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
Westinghouse freestyle fridge rj532s-r is leaking water inside fridge compartment
Good Luck
Sep 23, 2011 | Refrigerators
Can't remove lens cover on rear to access burned out bulb. Screws are out but don't want to crack the cover.
it may be possible that you don't have to remove the lens cover to replace the bulb, in most modern vehicles the bulbs come out from inside the trunk by turning the fitting & pulling the bulb out & replace it the same way by putting it back in & turning it in the opposite direction to lock it in place.......hope this helps......cheers.
Sep 04, 2011 | 2002 Mazda Tribute
Problem concerns Samsung HL-S5087W. All of a sudden, TV goes through 3 startup cycles and shuts down resulting in 3 blinking lights on front panel. What I've done: Completely cleaned inside of...
3 blinking led light at the front panel is an error code for lamp malfunction. If you've already replaced the bulb and yet the symptoms remain the same, then high chance that the fault came from the ballast board because the supply voltage is present.
Confirm if the bulb will lit upon powering on the unit. Open the lamp cover, bypass the lamp cover switch by putting tape to make it in closed position (making it still the lamp cover is attached to the housing) and then power on the unit. Check if the bulb will ignite or will light up, if not, you have to replaced the ballast board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 14, 2011 | Samsung HL-R5087W 50" HDTV-Ready...
Can't get the head lamp bulbs out removed The cover unplugged the light pulled the Wire harness down but the bulbs won't Budge
Almost all headlight bulbs have a bayonet mount with a rubber gasket. The bulbs have to be turned about 1/4 turn, usually counterclockwise, to remove them. If you have the new bulb, look closely at the mount on it. It will be helpful in knowing how the bulbs are installed. If the bulb has contacts that you push into the holder, the holder is what you need to get out. It will have the bayonet mount. Sometimes the bayonet is hard to turn if the gasket is stuck to the housing. However, don't use any solvent or lubricant because if it gets into the housing it can damage the mirror coating. Even moisture inside the housing can damage the coating, so be sure you install the new bulb correctly with the gasket in place. Be sure not to touch the new bulb with your bare fingers. The oil from your skin will burn on the bulb surface and shorten its life and light output. Never touch any halogen bulb with your bare fingers.
Gaker
Jul 05, 2011 | Volvo S80 Cars & Trucks
I have a used Beverage Air model # MT17-54. What size light bulb do I need, Lenght and wattage.
I Have The MT15-54 Used The Same Very Hard To Locate Bulbs & $$.
F28T8CW4 is a 28inch, Plus Ballast Replacement Cost(s).
I Got Rid Of That Setup, Removed Both Ballast and Lamp Holders.
Install Two 13W T2 Twister Fluorescent Energy Saving Screw In Bulbs,
I Call Them The Pig-Tail Bulbs, Less Energy & Heat.
Obtain a Dual Levington Incandescent Porclein Bulb Holder Assy, Part# 4005 and Mounted Inside Cooler/Front Side Only/Top Center
Between Evap Coil/Fan Cover & Sliding Door's, Little Room, But
Works Great w/Bulbs.
Lights Entire Inside, Plus If You Like Color Bulbs, Add's a Cool Look
At Night. Use Same Light Switch Installed From Bev-Air OEM.
Jun 13, 2011 | Kitchen Ranges
Light bulb replacement in a Tappan Microwave
Hi Mike.
Difficult to say on yours. You may try the following. On the back or side, if there is a little cover that's screwed into the panel. Otherwise browse around on the inside. Be sure to unplug the micro before checking. Once found be sure to replace with a microwave lamp and not a fridge lamp. There is a difference. Good Luck,JUS004
Feb 28, 2008 | Microwave Ovens
Refrigerators Logo
155 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
