The CD trays on my Fisher DAC-199 will not come out. The machine just hums. The door will sometimes open or close.
  • Audio Player... Master
  • 1,267 Answers
That is most likely a belt that has stretched with time. Some belts are easy to install and other are so that you must remove the transport to get at the belt location. The symptom is very common in belt type drawer systems. I see it all the time.
Posted on Dec 11, 2012
  • 883 Answers
SOURCE: CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Posted on Jun 04, 2007
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
SOURCE: Can't close door of CD on Sony CMT-CP1
Mine had the same fault. The CD is being rejected as it could not load up - this is probably because of the CD loading mechanism.
You'll need to unplug and remove the case - 4 screws on the sides and 4 or 5 on the back. Once this is done plug back in (be careful not to touch any live parts inside), load a CD and watch. What you'll probably see is that when the drawer closes the mechanism under the drawer doesn't lift sufficiently. Give it small push when it tries and I bet it then will and the CD will play.
What you need to do to fix this is remove the front panel/PCB and also remove the plastic cover that is screwed above the CD drawer so that you can see more of the topside of the mechanism.
Remove the front panel/PCB by releasing the 2 screws on the bottom and then easing forward. Gentle - as there are pins connecting the front PCB to the side PCB. You should then be able to see a worm drive type arrangement that lifts the lower assembly. This will need regreasing (I used vaseline) with a small stick (I used a Q-tip with the bud cut off). You will probably see where the old grease has been pushed out. Once you've done this, reassemble and operate a good few times to work the grease in.
Done! Mine works fine now after sitting there performing the annoying trick you described for many months!
Posted on Jan 08, 2009
SOURCE: Denon CD player DCD 920. When using the
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Posted on Oct 14, 2009
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
How can i open my cd drive to insert my cd?
If the button on the drive won't pop open the drive, then you need to find out what is causing it to stick closed. Most drives have a tiny hole on the door so you can push a paper clip in it to open the door.
Jun 17, 2015 | Computers & Internet
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
I just recieved a system fisher dac-9345 and the cd changer wont eject the cds what could be the problem
Sounds like you've got a problem with either the Drive Motor, Drive Controller or Drive Belt.
It could be an easy fix but it depends on the where the fault is.
Does it make any noise or effort to open the tray?
May 12, 2011 | Audio Players & Recorders
I have a Fisher Compact 5 cd changer Model DAC 197 . Manufactured in 1988. Are the small rubber drive belts available , if not, are there any that are inter changable?
I had the same problem. I took the cover off and tried to eject a tray and saw that the small rubber band was slipping. I simply got a smaller rubber band and replaced it. It works perfect now. It takes longer to unscrew the case than it does to fix the problem.
Dec 28, 2010 | Audio Players & Recorders
Karaoke Machine - words are overlapping/jumping
The Sining Machine #SMG-301 has a problem with not playing because of the word 'DOOR' coming up on the readout. I've checked the door/Tray to make sure that it was closed and when you open up the tray/door to put or take out another disk the word that comes up on the readout is not DOOR it's OPEAN! Any suggestions?
Aug 24, 2009 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
CD tray stuck
Problem is very simple, Switch off system, unplug from mains. Open the Cover panel, and remoove CD. Close machine. Plug into mains. Open Tray, put in anothrer CD, enjoy your music.
Mar 05, 2007 | JBL Harmony Shelf System
117 people viewed this question
 Grubhead
Grubhead
