Question about Sewing Machines
Husqvarna making squeaking noise
I haven't used my sewing machine in over a year and have recently wanted to make a few things but when I went to use the machine it made a squeaking noise only when I'm trying to sew. It also won't stitch anything and keeps saying that there is no thread (when I make the first stitch it makes a tangled mess and won't sew anything after that). It's a Husqvarna Viking 350.
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle
try a different bobbin--make sure the bobbin is turned the right way
in the bobbin case
also try a different thread
make sure the top has not come off the thread take up lever
also the machine may have a timing problem and need to be
serviced
Posted on Dec 08, 2012
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
WonderTech
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
SOURCE: thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Posted on Jan 25, 2010
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
Brother 1034d squeaking
but you can check with the place you bought it from & tell them it's squeaking alot, & see if it needs to be oiled, or if they want you
to bring it back to them to be checked
Aug 09, 2012 | Brother 1034D Mechanical Sewing Machine
Husqvarna Sewing machine #1 model:: Tech says that I need a new mainboard. Hate to put that kinda money in a 20+ year old machine. He said that it sews like butter now (also had to replace a fuse in
it's a hard decision to make, also another thought to trade the machine in for a new machine,, get a new machine with new features that you might use more
Mar 03, 2012 | Husqvarna Sewing Machines
Can you e-mail me the 1-800 phone # of husqvarna viking. i thought since i paid to get your answers to my problems & you haven't solved my problems, i paid for your services for nothing.
http://www.husqvarnaviking.com/us/19750.htmThis link will give you several methods to contact customer service.My advice here is free if you would like to run your problem past me.Let me know the model of your machine and what is does or doesn't do.I'll help if I can.
Sep 29, 2011 | Husqvarna Viking 1
Hi...I have a Toyota DC31 which I have to admit, haven't used for a few years because each time I've used it the bottom row of stitches kept snagging. I tried to slacken the tension but it...
hi, when a machine sit up for awhile, the grease & oil can because nasty, & it needs to have new fresh grease & oil put in it, & also check to make sure there's nothing loose or damaged. so having a machine service at least once a year is good.
if you could explain the problem more maybe I can help you. just send me a comment
Sep 13, 2011 | Toyota Sewing Machines
I have not sew with my machine in about a year or two do i oil it or just start to sew.. it not making no noise or any thing..
It depends on how many years you have owned the machine. If the machine is less than 5 years old, I would say that it is safe to operate it without oiling. This type of machine typically has few non plastic gears. If you wish to be on the safe side you can oil the machine according to the owner's manual. Be careful not to use too much oil.
May 16, 2011 | Singer 3116 Simple
Squealing noise Husquvarna 3310 sewing machine. Still sews ok but noise must be harming the machine. Anyone know what I can check?
My Designer 1 started squeaking recently and, like you, I was concerned even though it sewed like usual. I emailed my tech. and he suggested either feed lifter mechanism or feed cam were the most likely causes - simple to repair but I would need to bring machine in for him to hear because there could be other reasons for the squeak. Well I did not have time to go then and there. Next day when I sewed, the squeak was gone!
At the time it squeaked I was sewing through several fairly thick layers (making a pot holder) and sewing very slowly. The next day I sewed normal cloth at normal speed but no matter how slowly I sewed, I could not get it to squeak. I will get it checked eventually but as long as it is squeak-less I'm not going to be concerned.
If yours squeaks all the time no matter what you are sewing then, yes, I think you should get it looked at. Be sure that nothing is rubbing against the body of the machine i.e. accessory tray and making the noise.
Sep 28, 2009 | Husqvarna Viking 1
Have Viking 150E
I have to buy a walking foot for the Viking. Or get another Singer since the foot waqs originally for it and themachine died permanently.
Oct 12, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
80 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
