Question about Sharp Royal Alpha 9155SC Cash Register
Keypad does not work
Just the middle left to right row of numbers, the rest is fine
  • Sharp Expert
  • 592 Answers
Call a technician or just replace the whole keysheet
Posted on May 16, 2014
2003 ford windstar spark plug wires diagram
I\'m assuming you have the 3.8 engine,although i believe the firing order is the same on all there v6 sideways mounted front wheel drive Windstars. That firing order is 1-4-2-5-3-6, with 1-2-3 going from left to right on the back side of the engine and 4-5-6 left to right on the front side of the engine.Looking straight down at the coil from the front of the car,you\'ll see 2 rows of coil terminals.The row on the right side is 1-2-3 going from top to bottom,row on left side is 6-5-4 going from top to bottom. Hook the number 1 coil terminal to the number 1 spark plug ,being careful to use the spark plug wire that is closest in length to the length you need. If your just replacing wires,yuo shouldn\'t have to much trouble. If your nreplacing the spark plugs you will find the ones in the rear,especially the number 2 [the middle one} are pretty difficult without removing the cowling. A total pain brought to you by the designers at Ford!
Jun 04, 2014 | 1998 Ford Windstar
Diagram
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires go to from the Front Panel; is the Front Panel header
http://www.ebay.com/itm/ABIT-Computer-IC7-Socket-478-Intel-Motherboard-w-Pentium-4-3-0-GHz-CPU-/171034074235?pt=Motherboards&hash=item27d26cdc7b
Motherboard installed in computer case, the Front Panel header is on the Bottom/Right corner; and is White it color.
Two rows of contact pins.
(I like the Zoom In feature. Just set your mouse cursor in the middle of the photo to activate it, and then move your mouse cursor around)
Looking at the two rows of pins, you will see there are some missing in the middle.
Essentially can be said as having pins on the Left, and pins on the Right.
It is my belief that the pins on the Left side, are what you want.
Number the pins across the Top row
Let's start at the Left side.
Pins 2, 4, 6, and 8.
Now number the pins on the Bottom row, Left side.
Look like there may be four pins, so number from the Left,
Pins 1, 3, 5, and 7.
It is my belief that;
Pins 2 and 4 are for the Power On LED light
Pin 2 being for the Positive ( + ) wire
Pins 6 and 8 for the Power On switch
Pins 1 and 3 for the HarDDrive activity LED light. (HDD LED)
Pin 1 for the Positive ( + ) wire
Pins 5 and 7 for a Reset switch
I think the pins on the Top row/Right side, may be for a speaker.
A lot of times though, these pins are not even used.
One pin may have been a 5 Volt test area for the factory.
Other pins may be for technology that isn't used today, or used readily.
Such as Infrared Remote, and so on.
(Huh! Always thought Infrared was spelled Infared.
Good Ol' spellcheck)
I would SUGGEST, using a 2-wire LED to check my theory.
For additional questions please post in a Comment, or Reply; at end of solution.
Regards,
joecoolvette
May 07, 2013 | Abit IC7 Motherboard
Row of characters stopped working
Sometimes the ribbon connector becomes disconnected from the connector on the motherboard. You can fix it by removing the connector inserting a slim piece of plastic and reinserting the connector.
May 02, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Find the pattern of missing numbers
57
32 25
17 15 10
9 8 7 3
6 3 5 2 1
Apr 12, 2013 | Computers & Internet
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
Changed headlight, still not working. which fuse is for the highlight.
For E36, In the black front power distribution box located driver's side near the firewall. Low beam relay is #6 (middle row, 3rd from left) and high beam relay is #7 (middle row, 3rd from right)
Sep 18, 2011 | BMW M3 Cars & Trucks
What number the fuse number for the brake lights
The fuse for the brake lights is in the engine compartment fuse box, located behind the battery. Open the lid. Several fuses are marked but many are not. There is a group of 12 fuse sockets in the middle of the panel, arranged in 3 rows and 4 columns. The brake light fuse is in row 2, column 2. It powers left, right and middle brake lamps. If your brake switch fails in the ON position, you can pull this fuse until you can get a replacement switch. The drain of these lights being on can kill your battery overnight.
Jun 06, 2010 | 1999 Jeep Grand Cherokee
Gateway MX6124 laptop: some keys on the right side of the keyboard display numbers instead of letters. Keys involved and actual display are: Row Starting with q: u=4, i=5, o=6, p=*, Row Starting with a:...
Your computer is in keypad mode. To check, turn off your Num Lock. On my system that disables the embedded keypad. To fix, go into setup (usually F1, F2 or delete when booting). Somewhere you should find a setting for using the embedded keypad. Mine has two options, Fn Key Only and By Num Lock. Yours may be different. One activates the embedded keypad, which you are seeing. Try the other setting.
Apr 25, 2010 | Gateway MX6124 Notebook
Blocks puzzle # 57 in Nintendo DS 50 Classic Games impossible?
  1. Top Icon right (3 moves)
  2. Left Icon left (1 move)
  3. Sedond Left Icon left (1 move) clears 2 Icons
  4. Left Icon right (1 move) clears 3 Icons
  5. Top Left Icon left (2 moves) ends up on bottom
  6. Middle row Second Icon left (2 moves)
  7. Middle row Third Icon left (2 moves) clears 2 Icons
  8. Middle row Second Icon right (1 move) ends up on bottom
  9. Middle row Right Icon left (4 moves) clears 3 Icons
  10. Top Icon left (1 move) clears 2 Icons
  11. The Rest Is EASY!! (2 moves) clears 4 Icons
Jan 24, 2010 | Nintendo DS Lite
Sharp Royal Alpha 9155SC Cash Register Logo
79 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
