Question about Pioneer PD-M603 6-Disc CD Changer
My Pioneer PD-M603 CD player is making a high pitched noise
I have a Pioneer PD-M603 6-Disc CD Changer that was working great. Now I just get a high pitched whining noise and the CD won't play. I have the disc in properly and I have used a CD cleaner. Still nothing. Any ideas?
  • jeffnelso968 Jan 19, 2009
    Thanks for asking. It has a high pitched squeal once Play is pressed and it loads the CD. Everything looks OK on the display except the Time is blank. I found that leaving it for a few minutes will make it play. It works fine after that but still has the noise.
  • steve hall May 11, 2010
    Does this machine load discs correctly ie normal sped not slow
4 Suggested Answers
SOURCE: IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Posted on Oct 14, 2007
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
SOURCE: Is there a free manual
Yes -Please click on the link below to download it:
http://www.managemylife.com/mmh/lis_pdf/OWNM/97110208.pdf
PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Posted on May 15, 2011
Pioneer PD-M40 changes through all 6 cds but does not stop to read any of them
The laser pickup assembly is at the end of life, remove top to expose the laser lens, use a Q-Tip and rubbing alcohol and gently clean, allow several minutes to dry, if no change! far cheaper to replace the cd changer.
Jul 02, 2012 | Pioneer PD-M603 6-Disc CD Changer
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
Player wont recognize disc
Sorry for such a simple solution, but it has saved my but multiple times. Try cleaning the disk reader laser with a smooth clothe rag or material. Clean the dust or whatever may be on it. If that doesn't work, then I hope someone with more knowledge on this matter will help.
Mar 15, 2011 | Pioneer PD-M603 6-Disc CD Changer
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
The standard cartridge for the Pioneer PD-M501 is the Pioneer JD-M300 6-disc magazine, and you can find them at Amazon.com for $25 new. The JD-M300 fits a lot of different brands of CD players, not just this particular brand and model. And here's a link to a copy of the owner's manual: http://www.scribd.com/doc/22613342/Pioneer-PD-M601-M551-M501
Mar 26, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Changer works but display reads no disc
the lens on the optical pickup is dirty and needs cleaning. they sell a lens cleaner disk at any electronics store. you also might want to blow any dust out of the unit with canned air to prevent it from happening again.
Dec 17, 2009 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer pd-m406 cd changer magazine style
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
Pioneer PD-M603 6-Disc CD Changer Logo
185 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
