Screen issues Originally bought in 2005. We replaced the lamp bulb in 2011, now every time we turn on tv, it says reset lamp , also we get red vertical lines about an inch apart , all across tv, then in left lower portion of screen a green glow, circle around 4 inches, how can we correct this, also would it be cheaper to buy new tv, and what brand and type would you recommend? The red vertical lines come and go as does the green glow.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I think better to replace the set as all this sounds like a light engine failing.
Posted on Dec 22, 2012
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
  • 208 Answers
SOURCE: Green spot / glow in center left side of Panasonic PT-61LCX65 LCD Projection HDTV
This unit has a chonic issue with corruption in the eeprom that causes spots and shadows. The correction is to find some service center that has the jig to hook up to your unit and correct the eeprom. This is an extended warranty issue with Panasonic and if you contact them they should be able to refer you a qualifed service center and Panasonic will pay.
Posted on Apr 08, 2008
SOURCE: Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Posted on Sep 13, 2008
  • 336 Answers
SOURCE: replaced lamp in toshiba 46hm84. still get
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast is the most common failure besides the lamp.The ballast is the one that displays the lamp indicator if it's not able to power bulb or if bulb is not responding.Have a blessed one!
Posted on Mar 30, 2010
supertech6
  • 513 Answers
SOURCE: sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
Posted on Apr 21, 2010
Testimonial: "thanks, tv is only two years old and don't want to buy another one. Hope it is not the image engine."
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
How to reset the lamp operation time on a hitachi lp700?
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 31, 2012 | Hitachi LP700 Replacement Lamp
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Theres no picture
I have the same tv as you with the same problem. I'm sorry I have no solution for you but I can tell you that it will keep happening over and over and over again. We have had ours for just about 3 years now and have had to replace the lamp 6 times (it does the same thing to us, sound but no picture and then turns itself off) you can try to push the system reset button on the front panel of your tv but most likely that won't work. We have also replaced the fan and the light fixture twice. Best Buy (where we bought the tv) has now spent double what we originally spent on it just to "fix" it. I would recommend fixing the bulb and selling it as quick as you can unless you want to spend over $1000 a year on maintenance. We know 2 other people with the same tv just a smaller size and they have both had the same problems we are having. This model obviously has a major problem but neither Mitsubishi or Best Buy want to do anything about it other than temporarily fix it until my warranty wares out. Get out while you can is my advice to you.
Jun 03, 2010 | Mitsubishi WD-65731 65" HDTV
Lg tv will not turn on it is a micro projection 55 inch hd dlp xd hit power a hundred times and it will eventually turn on but this is what it does it will blink yellow the bulb will light up screen will...
Have you actually replaced the lamp first? A weakened lamp will often cause random shutdown or troubles during initial firing of the lamp. The LG televisions will be just the bulb itself not the complete lamp assembly. It's not hard to replace the bulb as long as you first allow the TV to cool down for a minimum of an hour. Then you will want to handle the lamp with latex gloves on to avoid getting oils from your skin on the bulb. You can find your bulb replacement at http://www.partstore.com
Nov 12, 2009 | Televison & Video
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
I cannot reset my lamp clock
http://answers.yahoo.com/question/index?qid=20080221185527AAvGCui
I just now replaced my lamp and tried the solution on the above bookmarked site (hold down VOL- on the TV itself while holding down the SPLIT button on the TV remote simultaneously for several seconds... I didn't need all 20 seconds that this site recommends), and that worked for me. About 5-10 seconds in, I saw a blue box on my screen that basically said "Lamp timer has been reset to 0" with an "Exit" box below that. It took me a while to find the "Exit" button on my remote control to clear that box off the screen, but that's how I cleared it.
My TV is just short of 3 years old; I bought my Panasonic PT-52LCX65 on "Black Friday" (day after Thanksgiving) in 2005. My lamp died last Saturday night.
Hope this helps! -- ChuckE
Jun 06, 2008 | Panasonic PT-52LCX65 44" HDTV
Hitachi model # 50V720
I have the same model and had the same problem after replacing the lamp. Turns out if the cover plate is not put back on properly, tv will not power on and lamp ligth comes on. To solve the problem all I had to do is tighten the cover plate screw. Hope this helps.
Nov 17, 2007 | Hitachi 50V720 Television
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
