Question about LG DLE2532W Electric Dryer
Check filter light flashing - dryer willnot start
I have cleaned the filter and the exhaust - light willnot go out and dryer will not turn on/
  • riggmom2004
    riggmom2004 Dec 08, 2012
    actually - there is a child safety feature that prevents the dryer from starting - once that was de-activated it started right up.
    Sergeant:
  • 239 Answers
Check the exhaust hose for crimping or blockage. Some models have a drum shaped inlet that slides over the fan housing inlet. A lot of times the lint literally piles up at the bottom in that inlet drum till it begins to restrict flow.
I changed the Drum belt on my Maytag this morning and, when I removed that part to get the belt around the drum, I was able to pull out a fist full of lint that had accumulated in that inlet drum that had to get by the lint screen first.
Posted on Dec 08, 2012
SOURCE: Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Posted on May 06, 2007
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
heatman101
  • 43501 Answers
SOURCE: LGDLE0442W Dryer check filter light on. Flter
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
Clean lent filter
The unit is seeing a restriction in air flow disconnect the exhaust at base of machine turn to air dry or fluff you should get good air movement coming out of the exhaust I will assume the machine worked when new if flow is weak then there is lint in the blower air passage from the machine if good you will know the difference the the restriction is in the exhaust exiting the house on one occasion i did encounter a bad control if everything passes the test an dryer is operating correctly and you still have a light leave it control is not cheap for an annoying light
Mar 21, 2014 | Maytag EPICz Electric Dryer
The 'clean filter' light keeps flashing and even though I've cleaned the filter, inside the vent area, etc., it still is flashing and won't turn on. Suggestions?
CHECK THAT THE EXHAUST HOSE IS OPEN AND NOT FULL OF LINT OR BLOCKED. OR TAKE HOSE LOOSE FROM BACK AND SEE IF THAT RESOLVES PROBLEM..
Mar 11, 2010 | Dryers
Check filter light wont shut off and setting.lg tromm dryer
Dec 23, 2009 | LG Dryers
Lg dlg2522w check filter flashing, motor spins,no
Did you put a load of wet clothes in the dryer and run it?
You can't change the setting while it's running.
The sensors won't let it heat up if there is nothing in the dryer.
This is not your grandmas dryer, this is a high tech machine.
There is probably nothing wrong with it.
Oh and the filter light flashes like that, it is supposed to, it is telling you to check the filter for lint.
Nov 24, 2009 | Zanussi FJD1666W Front Load Washer
Lg tdc70040e I have this dryer. I dont start
Make sure the exhaust vent line is not clogged. Check the entire length all the way to the outlet.
Jul 19, 2009 | Dryers
Dryer shuts off on own lights blink
Turn off breaker wait an hour turn back on.
Apr 03, 2008 | LG DLE2514 Electric Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
LG DLE2532W Electric Dryer Logo
101 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
