SOURCE: EOS Kiss X2 English User Manual required
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
find the model and download
SOURCE: language change from japanese to english
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
SOURCE: How do I change the language from japanese to
Press the power button. Set the mode switch to playback (the right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use the arrows to select a language. Press the FUNC/SET button.
SOURCE: sony cybershot dsc-w270 japanese to english settings??
Press the MENU button to bring up the main menu. Use cursor-down to select Settings (toolbox icon) and press * in the center of the cursor pad. Use cursor-up/down to select Main Settings (wrench and hammer icon), press cursor-right, and then *. Select the second item on this menu.
SOURCE: The language on my Canon
Follow the correct instructions below based on the diagram to change the language of Canon EOS 5D Mark II from Japanese to English;
1.Press the MENU button.Different tabs are displayed on top of the screen as shown below.
2.Turn the Main Dial to select the Setup Tab ( The one with two dots and a spanner) on top of the screen.
3.Under this tab Turn the Quick Control Dial to select [Language] ( the third item from the top ) and press the SET button.
4.To select the desired language use Main Dial or Quick Control Dial (The current setting is indicated in Blue) and Press the SET button.
5.The desired language is set.
Thanks for choosing Fixya
