Question about Car Audio & Video
Boss bv9993 wire for key 1 and key 2
What do these wires connect to?
  • worthg1
    worthg1 Dec 14, 2012
    I think it has to do with the steering wheel controls
2 Suggested Answers
kenw392
  • 2226 Answers
SOURCE: connecting power antenna to boss 9150 blue wire
usually there a three wires going to a power antenna. one is constant, one is switched (goes to blue wire) and one is ground.
Posted on Mar 02, 2011
My fan motor terminal connection to wiring are all cut no color wire all live wire how do i connect it
no numbers, tags or colors on the motor leads or the wiring? Tracing each wire, investigating for clues may get you in the right path. A motor with a capacitor is wired so that two motor wires, (T1 and T2) connect to power (L1 and L2) and a third wire connects only to a capacitor, the other side of the capacitor connects to line 2.
If the motor has 4 wires, then two wires connect to power and the two brown motor wires connect to a capacitor.
Motors with a brown wire with a white line is the same wire as a white wire off the motor. This makes the sold brown wire connect to a capacitor by itself and the brown with a white streak or the white wire connect to the other side of the capacitor where a power line wire connects and the other power line connects to the remaining motor wire. Confused? Draw it out on paper as explained and draw what is actualy on your unit.
Apr 30, 2015 | Heating & Cooling
What do I do with the red wire on a Brinks Halogen Motion Sensing outdoor security light
Please perform these connections with the mains power off.
The standard is the Black wire is hot, the White wire is neutral, and the Red wire is switched. For your Sensor connection 120V is connected Black to Black and white to white while the Load is connected White to White and Black to Red (assuming your load is using standard color coding.
Here is a simple diagram for your connection.
Mar 01, 2015 | Electrical Supplies
What am i doin wrong with my boss radio? when i set a station when i shut the engine off i loss my settings
Sounds like your Memory +12V wire is not connected properly. If this wire does not have a constant source of power then you will lose all of your settings on your radio.
Things that may cause you to lose power through the Memory 12V wire:
  • Not hooked up properly to the battery
  • Bad battery
  • Bad ground
  • Loose wires
Boss 637UA manual
Sep 04, 2014 | BOSS AUDIO SYSTEMS BOSS 637UA - radio / CD...
12V POWER
12V switched means that the connection is controlled by the Key position. If the vehicle is off and key out, then the radio cannot be turned on.
Jul 13, 2014 | Boss MR1308UAB
Trying to connect a Tork A530 MW timer to a spa tub pump
  1. The white wire (neutral) in your feed cable from the electric panel should be connected to the white (neutral) wire going to the pump.
  2. This switch is wired in 'series' in the hot (black wire) leg. That means one black timer wire connects to the black wire in the feed cable from your electric panel and the other black timer wire connects to the black wire that goes out to the pump.
  3. I the diagram the switch is your timer and the light bulb is the pump. The switch is in series with the pump.
Nov 13, 2013 | Tork Spring Wound Interval Timer
Usb is always loading on boss bv9993
Yes, I just got this unit and installed it today. The reason for this is this unit isn't capable of playing the ipods. You have to put the music on a flash drive to use the usb function. Which to me wasn't a big deal because I only use my ipod in my car anyway. The bv9999bi is the newer model of this unit and can play ipods. But i wasn't going to send this one back to get that one cause then I would have to pay for reinstallation when I could just put the songs on a flash drive. I love this unit btw.
Dec 23, 2012 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Car Audio & Video Logo
177 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
