Question about Weaver Optics
Manual for weaver j 2.5 - Weaver Optics
I have lost the caps that cover windage∧ elevation dials on my k4 scope , can you help me out
Put "Weaver scope caps" in the search box at eBay. You should find some listed. Also, Iron Sight Inc. repairs Weaver scopes, you might try them.
Dec 19, 2014 | Weaver Hunting Gear Polar Caps Size G...
Unit does not turn,I think it needs a switch,looking for some place local for repair.Returned to weaver twice problem still exists
Jemenie!!! Apparently Weaver doesn't know what to do. Call the big boss and give a ear full.
It could be a bad switch, broken wire, bad image tube, faulty ccfl inverter, multiplier. Without some troubling shooting it, it is impossible to tell. stewbison
Feb 26, 2011 | Weaver NightView (849397) Monocular
Directions for mounting weaver 1inch see thur scope mounts
there the same as any other mounts,,, screw then down on a wever mount and plonk your scope into them,,,then re-zero the scope
Nov 27, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
How to readjust a weaver mount?
Make sure the nuts are on the same side of the rifle (both on the right OR left). The clamping mechanism can vary the centering of the scope if they are on opposite sides of the mount.
The other problem may be poorly drilled mounting holes on the receiver or scope mount, check these for alignment with your bore or barrel.
Mar 15, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
What kind of base would you use on a TC pro hunter
You base must be compatible with the type of mounts you use. You will have to get a gunsmith to fix them so if you decide to use weaver mounts for example, the logically you would use a weaver rail. Be cause different mounts have different holding methods, first select the scope you are going to use. Once decided then find a set of mounts that you are happy with and from there you select a rail that will accommodate your mounts.If in any doubt, ask the person who is doing the work for you for advise.
Feb 13, 2010 | Weaver Optics
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
Weaver T-36 scope fails to hold zero
"Iron Sights" in Tulsa, Ok does service work and has parts for the original El Paso type Weaver scopes.
They have did an excellent job on my old Weavers.
They are slow turnaround, but excellent work.
May 21, 2008 | Weaver Riflescopes T-Series Adjustable...
Optics Logo
Top Weaver Optics Experts
Mark Campeau
Level 1 Expert
freebyrd04
Level 1 Expert
colinat108
Are you a Weaver Optic Expert? Answer questions, earn points and help others
