Question about Exercise & Fitness
Torpedo exercycle FN 10243 needs part no 21 to tighten the tension
I need part no 21 for a torpedo exercise cycle model no FN10243
Crossedwires
  • 44 Answers
SOURCE: 3 core torpedo switch, how do I wire it?
BEFORE YOU PROCEED. PLEASE NOTE THAT THIS INFORMATION IS FOR TRAINING PURPOSES ONLY. USE IT AS YOU FEEL COMFORTABLE WITH. I MAKE NO GUARANTEES TO YOU OR YOUR EQUIPMENT!!
Easiest way is to follow the old switches wires. However, if that is not possible. In electric circuits, White is always neutral, green is always ground any other color could be whatever. Most likely they will be hot. PLEASE NOTE-- This is only true with electric wires. Electronic wires will be different! It is important to understand that and know which code the fan is following. Most fans will follow the electric code but you best find out first! To wire this up, you will hook the hot wire to the center contact of the switch and the wire going to power up the fan will be on the other contact. The neutral should be straight wired through, not to the switch! I would also advise going to a hardware store or store that sells electric supplies and see if they have a how to book on wiring fans etc... That would be the wisest starting point!
Posted on Feb 09, 2008
  • 21 Answers
SOURCE: need UK wiring diagram for a 2 amp torpedo switch ( 3 terminal)
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Posted on Feb 10, 2009
projdoc
  • 2237 Answers
SOURCE: torpedo projector
if no lamp strikes at all, could be lamp or ballast needs replacing. if it doesn't turn on at all, it's the power supply. if the lamp is on but no image, may be input signal.
Posted on Aug 19, 2009
  • 193 Answers
SOURCE: Hi, I need parts for a kerosene torpedo heater.
You need to call Portable Heater Part in Valparasio,in for replacement parts
Posted on Oct 18, 2009
  • 224 Answers
SOURCE: torpedo heater shuts off after several minuets,
These heaters require some preventative maintenance from year to year and here is my routine. There is a flame sensor in the burning tray, these collect carbon deposits, dust and dirt, and occasional insect nesting area. Locate the flame sensor by removing the top half of the heater, now remove it and clean with windex and soft terry cloth rag. Replace sensor and be sure it has an unobstructed view of the flame. Fuel is next, with the top still off locate the fuel nozzle, remove it and the say you can not clean these but I find that carb cleaner, q-tips and a tooth pick work just fine to clean them. Now when you remove the nozzle there is a screen filter directly behind it, these can corrode over storage so clean it too. Now inspect fuel lines for cracks, holes and dry rot. Put fuel system back together and the top on. The fuel line comes down thru the side panel and thru a filter then in to the tank. Remove side panel, locate fuel line, remove the filter and clean with a compressor and air gun. Blowing air thru the filter backwards will clean these right out. Put it back in line, put side panel back together. Next is the air filter on the inlet of the pump, they are foam. Clean this and dry it real good then put it back. Really look in the fuel tank to make sure you have no water,rust, or any other contaminants in the tank, fill with new fuel and you are ready for heat. Sounds complicated but really isn't, take your time and in an hour you will have this heater running like new.Good Luck
Posted on Dec 23, 2010
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Fuel pump seems to have quit, need location of fuel pump Was looking for schematic of R155 Reddy Heater
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 05, 2011 | Reddy R155D Utility Heater
Need electroed part #0344-3 ready heater rem60 or r60 or rm60 60;000 btu
Any parts you need for any Dayton products can be purchased from Grainger...
www.grainger.com
heatman101
Jan 16, 2011 | Dayton E48 Oil Filled Utility Heater
Exercise & Fitness Logo
59 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
