Question about Mitsubishi WD-Y57 57" Projection HDTV
Connecting pcto the tv
I am having the hardest and most annoying time trying to connect my pc to my TV please help
  • 59 Answers
Some pointers
vga is an anolog signal
dvi-i is digital
hdmi dvi-i same signal
use a vga to hdmi converter like this
http://www.monoprice.com/products/search.asp?keyword=4629
worked for me
Posted on Jan 23, 2009
Panasonic th 37pw5 tv
Sorry if this is late. I have the same issue and I have found I have to disconnect the receiver box before the pc function works. It is annoying to say the least
Feb 09, 2014 | Sony Computers & Internet
Blinking screen after TV connection
dumb question... have you tried pressing the fcn keys to change your video output?
May 11, 2012 | IBM Lenovo ThinkPad L512 444434U Notebook...
Connect pc to tv
You will need a cable that connects the tv to the pc. If you pc has a vga connection and your tv has a vga connection, then you would purchase a vga cable and connect it. If the computer and the tv have 2 different types of connections you will need some type of adapter between the two of them.
Once you get them connected with a cable you just turn the tv on and Select Input (Select either PC, Computer, HDMI) of where the tv should receive the signal.
On the pc if you just reboot it most times the image will appear on the tv. if not you can Press and Hold your FN function key at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the display. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display.
Apr 28, 2012 | Computers & Internet
I have an lg 32ld350. I plugged in headphones into it as to not annoy anyone with the tv and when i was done i unplugged them and now i have no sound unless i use headphones. Even with them unplugged it...
Turn off ur tv.Tries take the head phone steal jack plug it in and unplug it out do this like three or four times.Tries the tv menu audio resetting again.The audio should return.Don't used ur tv head phone again the input jack socket it have problems,just lower ur tv volume for not to annoy anyone.Or used the tv head phone jack socket again will damage it for good, and will never get sound out throught ur tv speaker again.
Apr 16, 2011 | LG 42PX5D 42 in. Plasma HDTV
I have a dreambox 500. it is streamed through virgin broadband, 20 MG speed, a direct cable is attached from the router to the box. works perfectly sometimes, but other times freezes annoyingly, any...
please check if the same issue is when connection is direct to the modem of your Internet ISP.
Is happen only with your router settings in your router have a conflict.
Dec 17, 2010 | Jaton XMEDIA DREAM BOX TV/VIDEO TO PC...
Laptop connection to TV - Sound Problems HELP!
#Select the best HDTV package for PC and laptops to suit your needs. #Plug HDTV USB Stick into any USB port on your computer.
#Connect your Antenna cable, cable TV cable, or satellite cable to your HDTV USB stick.
#Install your TV tuner software.
Jan 14, 2010 | Sony VAIO (PCWA-A200)
Connect VCR to HDTV
If there is an extra AV connection just use that. Now note that VCRs have inferior picture quality compared to DVD. No matter what you do you will never get the crisp picture you get from a DVD. In fact I don't even use vcr anymore because they are outdated. Since you have an HDV it would be a great idea to enjoy blu ray on in it as well. Blu ray palyer are getting cheaper now.
Aug 11, 2009 | Televison & Video
When I turn sony kdl32m4000 on, green power light comes on but
I understand that your TV is turning ON but you're not bale to view the videos on the TV screen. If the TV is connected to a wall outlet through a Surge protector please disconnect the connection through the Surge protector and try connecting the TV to a working wall outlet and check if that helps. Please check the connection between the TV and the connected device. Please try using a different device and check if that helps. This is to check whether the issue is with the TV or the connected device. Please try to explain the issue as much as you can next time. What are the video sources connected to the TV? Does this issue occur with the TV when connected to other devices? How did you connect the videos sources to the TV? Which connection are you using to connect the devices to the TV? You TV doesn't support 1080p resolution, so please check whether the connected device is giving output in 1080p resolution. If the issue still persists service of the TV is recommended.
Jun 16, 2009 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Connecting my laptop to my tv
i think u guys need to connect the laptop to the tv with the laptop off. and pc mode should come up when ure changing sources. then u should be able to just function F6 or whatever it is to put it on screen. im currently looking foor an answer to why it does not just got pc mode without me doin this? im lucky as i have my pc tower sitting next to my tv so i can just plug it in and then switch it to the laptop when ive got the tv in pc mode. but it gets annoying so if anyone knows how i can configure the tv to just switch to pc mode even if nothings connected that would be great.
Nov 26, 2007 | Televison & Video
Mitsubishi WD-Y57 57" Projection HDTV Logo
136 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
