Question about Panasonic Televison & Video
WHAT DOES ERROR CODE U61 MEAN ON PANASONIC DVD PLAYER
SOURCE: u61 on panasonic dmr es15
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
Posted on Jun 03, 2008
shinma
  • 5 Answers
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Posted on Sep 21, 2008
SOURCE: Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
Posted on Oct 17, 2008
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
virtualhost
  • 2185 Answers
SOURCE: U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Posted on Aug 17, 2009
My dmr-e50 ca not play any disc it display dvd drive eror
What is the error code being displayed? is it U81 U61 or U99? U61 is likely to be a DVD drive error. U99 is an electrical problem, while U81 is a microprocessor feedback information error. Your best option is to submit this recorder to a qualified service technician in an authorised Panasonic workshop, for a quote, and a second opinion on the likely repair costs and/or parts involved. (it helps to be more specific when posting questions here about DVD drive faults so we can advise people properly on the best course of action to solve the problem (however a few consumers do not know what device error codes are and what they mean; this is understandable in many cases).
The cost to fix this unit depends where you go and whom you deal with. It is up to you, but be warned; if the unit needs a new DVD drive, this could prove expensive.
Apr 07, 2011 | Panasonic DMR-E50 DVD Recorder
Panasonic dmr-es46v player recorder error code u61. what do i due
That error means: There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
I suggest you unplug all the cords o the unit and after 2hrs replug and see if the error is gone.
Let me know the result.
Thank you for using fixya.
Jan 03, 2010 | Panasonic DMR-ES46VS DVD Recorder/VCR
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
Sep 21, 2009 | Panasonic DMR-ES35VS
ERROR CODE U61 panasonic dmr-ez45v
I HAVE A DMR-EZ45V WITH PROBLEM U61 IS THERE ANYWAY OUT OF IT
May 05, 2009 | Panasonic Televison & Video
From User guide:
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
Error code U61 on a panasonic DMR-ES35v
component failure, the DVD Disk Drive Control Board
(Part No. VEP79132).
Panasonic will not sell this individual part but packages it a module, called the RAM/Digital PCB Module
(Part No. RFKNES15P).
Aug 20, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
Aug 04, 2008 | Panasonic Televison & Video
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
Please Do !
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Televison & Video Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
