Question about Panasonic KX TGA106 Phone
The headset will not ring
The base and 2nd headset will ring, but this one will not. I have changed the settings to ensure ringing is enabled.
  • 201 Answers
SOURCE: Message Greeting
The KX-T7456 is a proprietary system phone. You have a Panasonic phone system and a voice mail, both separate items with their own part number. Your phone can work on several different systems and use different voice mail so your first step is to determine the part numbers from the system and voice mail. Then you will need a "programming" manual or possibly "administrator's manual" NOT a "user guide" for at least your voice mail and maybe for the system as well.
Posted on Oct 17, 2007
realbat2
  • 68 Answers
SOURCE: Panasonic KX-TG6700 - want to turn off/down a phone line
please refer to this link
http://service.us.panasonic.com/OPERMANPDF/KXTG6700.PDF
n look at page 38
hope this help.... ; )
Posted on May 27, 2009
stwill2326
  • 77 Answers
SOURCE: the phon is not ring only the base is ring
look on both sides of the handset for a ringer on/off switch.
Posted on May 30, 2009
  • 19 Answers
SOURCE: enabling a extension to ring on night mode
We may need to know the exact system you are using and the model of phone.
Also we will need to know the group number the system is using for night mode. Normally group number 601 is day and 602 is night. If you call 602 that would ring the phones currently in night. Also you can try calling at night and watch the screen of the phone that rings if its a smaller screen phone press the info button while its ringing and one of the options will show the night ring group number as well.
Respond to this and I can further help.
Posted on Aug 10, 2009
  • 131 Answers
SOURCE: PHONE CUTS TO MESSAGE AFTER 2ND RING. I WANT IT
if answering machine is on phone , go to messaging menu it should have a setting for number of rings... make sure toll saver option is off!
Posted on Nov 09, 2009
Tip
How to fix or repair your phone if it doesn't ring.
Please try the following troubleshooting tips:
Ensure that your phone is powered on and that there is sufficient signal strength. When you are at the start screen or in a call, the strength of the radio signal is indicated by the signal indicators on the left side of your phone''''s display. These indicators move up as the strength of the signal increases and down as the signal decreases. If there is a headset attached to the phone, it will not ring. You should be able to hear the ringing through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
Check to see if the phone is in the "Silent" profile. If the phone is in the "Silent profile", change the "Silent" profile to the "Normal" profile and retest. To change your profile, please refer to your user guide.
Ensure that a ring tone has been enabled and the volume is not too low. (Please follow the instructions in your user guide.) If your phone goes straight to voice mail without ringing and your phone is powered on and you have sufficient signal strength, your service provider may need to reset your voicemail services. If your phone still will not ring, please submit your phone to repair so they may try to resolve the issue for you.
on Sep 28, 2010 | Cell Phones
Tip
Phone is not ringing
  • Ensure that you phone is on and that there is sufficient signal strength.
    • Signal strength is indicated by the signal indicators at the left side of the phone's display,
    • These indicators move up as the strength of the signal increases and down as the signal decreases.
    • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
on Sep 13, 2010 | Cell Phones
T7316E - Phones just installed. None of them ring.
You need to ensure that the main bell is programmed to ring, also that the extensions are also programmed to ring as well. Also check that the ringer is switched on, on the base of the telephones. Also ensure your handsets to not go over the ren value permitted. Make sure the service is on the correct day service and not night service. Check that the handsets ring internally and ensure they are registered with the system. Ensure that the connections and wiring are also correct,
Mar 15, 2013 | NorStar T7316E Telephone
I just got the Jabra GO 6470: The desk phone doesn't ring in the headset, so if you're not within hearing distance of the desk phone (but within the 300 foot range of the base) you don't know...
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Jun 15, 2011 | Jabra GO 6470 Wireless Headset with Touch...
Keep getting message "incomplete data" when a call comes thru
You've probably enabled caller id CLI on your phone but don't have it enabled as a feature on your phone line.
Hope that helps
Jan 14, 2010 | RCA ViSYS 2-Line Speakerphone
Headset button will not lift receiver unless ringing
You should be able to press the button on the headset as many times as you like and the lifter will respond, whether the phone is ringing or not
Mar 24, 2009 | GN Netcom GN 9350 Wireless Headset
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Oct 28, 2008 | Jabra T5330 Wireless Headset
Panasonic KX TGA106 Phone Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
