Question about Whirlpool Refrigerators
How long before you can plug in youre refrigeartor when you just recieved it
  • Whirlpool Master
  • 4,655 Answers
If you unplug a refrigerator you should wait at the lease seven minutes to ten minutes for the pressures to equalize befor plugging the power back in, Thanks Sea Breeze
Posted on Dec 08, 2012
New turntable has rca out but a miniplug for reciever connection
If your receiver only has a mini plug in you will need a phono pre amp that takes phono in and pit line level out. Then you can use an rca to mini adapter to plug into your reciever.
Feb 13, 2015 | RCA Audio Players & Recorders
Cannot receive fax
make sure you have a phone line plugged in correctly (into the in plug) and set the printer / fax to recieve auto. Do not pick up the phone while recieving the fax, If thei does not work, check your setting in the software.
Apr 10, 2014 | HEWLETT-PACKARD Office Equipment &...
How long before you can plug in youre refrigeartor when you just recieved ti
If it wasn't laid down you can plug it right in. If it was laid down, wait 24 hours.
Dec 08, 2012 | Whirlpool Refrigerators
Refrigeartor not chilling, freezer not freezing
If you have built up ice inside the freezer walls, and the defrost assembly isn't functioning, this could be the problem.
Defrost the unit! Take all the food out of the freezer side, remove shelves; remove inside back panel. If there is a lot of ice build up there, then your defrost assembly is not working or your refrigerator is not a frost free unit. Defrost either by leaving the freezer door open over night or you can speed the process up with a hair dryer. Once the ice build up is dealt with, you can plug the refrigerator back in and see if it will now freeze the freezer and chill the refrigerator. If it does, and you have a defrost assembly you need to order it and have it on hand when the ice builds up again.
Jun 05, 2011 | Refrigerators
My GE refrigerator is not working
in the refrigeration section there is a fan assy and damper assy, theis assy is really one kit and needs to be replaced.
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
No sound when the tv is on and the mute is turned off
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Feb 25, 2009 | Panasonic PT-52DL10 52" Rear Projection...
I have a JENN-AIR side-by-side refrigerator Model # JCD2389GE. The freezer side works great but the refrigerator side barley gets cold. Help!
the damper on the left corner in the refrigeartor is not opening is either blocked with ice or broken also when the frezeer is not defrosting like it supost to it blocks air circultion to fresh food section check both thing damper and defrost
Nov 09, 2008 | Refrigerators
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Getting the speakers to work with the TV
Yupp(depending on how old your stuff is) I will assume your using cable and using your tv to switch the channels. Look at the back of your tv there should be a audio output, plug some RCAs (red, and white) into the designated spot and now look on the back of your reciever, it should have a tv input, if not just a input. After that is done turn on the tv and put the reciever on the channel that you plugged it in. For example if you plugged the rcas into Tv input...then you would set the reciever to TV
Mar 25, 2007 | Koss KS2503 System
Refrigerators Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
