Question about Kole audio Q2-480 Car Audio Amplifier
How should I wire up this amp and sub
OK here is what I have, and I cannot find my amp manual. Kole Q2-480 amp Amplifier Type Dual Channel Bridgable Bridgable RMS Power at 4 Ohms 100 W x 2 RMS Power at 2 Ohms 125 W x 2 Performance Frequency Response 10 Hz - 30000 Hz Signal to Noise Ratio 98 dB THD at Rated RMS Power 0.02 % Crossover / Equalizer Bass Boost With Bass Boost Low - Pass Frequency 30 Hz - 500 Hz High - Pass Frequency 50 Hz - 500 Hz Other Features MOSFET Circuitry Yes 3 Way Ready Yes ------------------------------ Audiobahn AW831T 8" sub # 8" Natural Sound Subwoofer # 30 oz. Strontium Magnet # Power Handling: 200 watts R.M.S. # Frequency Response: 30Hz - 1kHz # Efficiency: 90.3 dB # PHAT Foam Surround # Non- Pressed, Non-Transfer Paper Cone # KM3? Coated for Virtually No Cone Distortion # 1.5? 4-Layer ASV Voice Coil # Dual 4 Ohm # 2 Ohm or 8 Ohm Operation --------------------------------- Empty MTX thunderform -------------------------------- Whats the best way to go about wiring this? The way I did it to test it out, was to bridge the amp, have the amp + wire to go the + terminal on one coil, the - amp lead to the other coils - terminal, then run a wire from the remaining + and - terminals on the sub. This sound right? Was pumping far less bass than I expected (and I wasnt expecting much) so want to make sure I am not doing this wrong.
  • 2 more comments
  • Ray jjj Jun 10, 2007
    The way you described to wire it is the way I had it. I have it like the pic at this link, to be sure is that what you were suggesting?
    http://akamaipix.crutchfield.com/ca/lear...
    Oh and thanks for the REALLY fast response! Do you think this is the way it should be wired?
  • Ray jjj Jun 11, 2007
    No way to get that sub to run at 4 ohms is there? I know the amp runs at 250rms @4ohms bridged. I may look for a new sub anyway, this thing doesnt fit all that well in my thunderform anyway!
  • Ray jjj Jun 14, 2007
    Thanks for the help and fast responses. I have up on that sub and am looking for something new. The shallow mounting depth of 3 7/8 is going to make finding a decent one a chore!
  • 156 Answers
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Posted on Jun 10, 2007
  • Brian Neathery
    Brian Neathery Jun 11, 2007
    Yes, I misunderstood your first description. I think the first diagram is the safest way to wire it. Here's the deal: the first diagram results in an 8-ohm load for the amp. This reduces the amplifier's power output in bridged mode, but the amplifier can run it safely. The second diagram, with your subwoofer, would result in a 2-ohm load at the amplifier. This would result in much more power, but there is a risk that the amplifier could overheat and shut down, or (in extreme cases) might result in amplifier damage. Most 2-channel amps aren't stable with a 2-ohm load in bridged mode.
  • Brian Neathery
    There's no good way to run that sub at 4 ohms. What you need is a single voice coil, 4-ohm sub rated for 250 watts; or a dual 2-ohm voice coil sub. Good luck!
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
Kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Mar 09, 2009 | Kole audio Nitric XP2-2000 Car Amp
How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Connecting a subwoofer to a mono amp that has 2 sets of terminals
ok this gets confusing sometimes. Ok first look to see what ohm your subs are. If you have a dual 4 ohm sub When you run that on sub + to + and - to - then that will make that sub 2 ohm. its different on ohm if the sub is say a 8 ohm then putting the wires that way will bring that sub to 4 ohm. Now lets say you have 2 subs that are dual 4 ohm and wire both of them + to + and - to - and go bridge the amp which would be both wires from sub both + together and both - wired bridge on the amp will make it a 1 ohm to the amp. Please post what ohm your subs are and i can tell you alittle more about it
Oct 21, 2008 | Verge VGA300M Car Audio Amplifier
1211a amplifier
if your amp. work in bridge you can attach + 1st channel and + 2st channel to your sub woofer. by series 2 ohm you have 4 ohm sub woofer.
Sep 26, 2008 | Infinity Reference 1211a Car Audio...
Kole Q1-3000D Power Supply caps Keep blowin
you need a fuse of 300amps or higher with 1/2aut cable power supply connected to an after market altenator. also make sure the subs are wired properly.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Kole audio Q2-480 Car Audio Amplifier Logo
1,005 people viewed this question
Top Kole audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
