Question about Acer Aspire One 11.6" 722-0432
Acer aspire one 722 crashed and Alt F10 won't work
After about 9 months of using my Acer netbook problem free, it suddenly crashed with out warning. It won't start up at all. All it does is after the Acer screen when I restart it it goes to a black screen that says no bootable device. I've been told this means it crashed and I can try restoring it to its factory default pressing alt and F10 at the same time when its on the Acer screen but it does nothing at all but go back to the no bootable device screen. Then I tried checking if the D2D recovery was enabled and it is. I'm really at a loss of what to do, I know very little about computers please help!
belloso2
  • 71 Answers
SOURCE: My Acer Aspire one Netbook XP(SP3)'s system recovery doesn't work
Are you trying to access your original recovery software the one that is located on a separate partition? If you are and aren't able to, that particular partion might be currupted. your only option would be to try to install your software with a disc.
I hope this helps.
Posted on Apr 10, 2009
joecomputer
  • 92 Answers
SOURCE: Black screen NTDLR Press any key to restart
It sound like your hard drive has crashed. There is no easy solution to your problem. Here are a couple solutions. You need to run a "chkdsk". It will scan and fix file problems on your HD. To do this you can either download a boot disk like "Ultimate boot disk" or you can take the HD out of your laptop and attach it to another computer. Neither of these are easy, for the boot disk you need to have software that can burn a "iso image" to a cd and to attach the HD to another computer you have to have the proper adapter. I would be happy to walk you through either one of these, just let me know. The easist thing to do would be to contact Acer and get recovery cds then go buy a new hard drive. I would take the old one to the store, to be sure I got the right replacement HD.
Posted on May 27, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Acer Aspire One AOD150 Won't Boot
The netbook is trying to find a bootable device. It cannot read the hard drive, so it started looking for a network hard drive to boot from, since it did not find that it continued down the line until it asked if you wanted to go to recovery. Most likely you have lost your hard drive and the netbook is simply trying to find the next boot device.
Posted on Apr 23, 2010
redgun10
  • 18 Answers
SOURCE: i have a Acer Aspire One D255 and the screen wont light up. shinning a light. to the screen i can see it is not frozen. i am able to. log in and. axcess the apps. easy fix? please help
I would like you to try two different things.
First press and hold FN then press f5.
If that didn't work try holding FN then pressing the left or right arrow(depends on the computer, not sure which one it is) to make it brighter. You may have to press it multiple times.
Posted on Apr 09, 2013
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
ACER ASPIRE ONE 722 PE1VE6 // STILL NEW BUT IT WILL CRASH DUMP. WHAT'S WRONG WITH IT? IS IT OK TO INSTALL SKYPE ON IT?
Hello.
If your Aspire is new and getting these errors, there may be a hardware error. If so, return to the manufacturer if still under warranty.
Check hardware by pressing F8, F10, or F12 repeatedly and loading diagnostics. Run the diagnostics and see if the hard drive has problems.
In either case, return the Aspire One.
Hope this helps.
Aug 28, 2011 | Acer Aspire One AO722BZ454 116Inch HD...
System won't start and don't have recovery disc
Hi
you could try this
press the power on key
then straight away tap the alt tab bottom left along with the F10 tab top right
so its
power on
Alt+F10
this will hopefully take you into the factory recovery options
and choose what you want to do
then follow on screen instructions
hope this has helped you
please let us know if it did or didnt
so we may be able to help others
many thanks
Aug 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
All the help sites I can find (including the acer site itself) says upon hitting the power button to hit Alt+F10 (of Alt Gr+F10) to load the screen I need to restore my Acer Aspire One netbook to factory...
www.bleepingcomputer.com If they can't tell you what to do there they can tell you how to fix the problem your trying to resolve by doing a system restore.
May 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to reset myacer to manufact setting
  1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
  2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
  3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
  4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
  5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
  6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Nov 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have acer aspire 3002lci . I want restore factory settings. I won't have recovery cd.How to do? i had done with alt+f10 it doesn't work.
The ALT+F10 routine should work if the ALT key is held down and the F10 key is repeatedly depressed before and during the Acer logo display.
If you still have a working M/C then the recovery routine can be accessed from START / ALL PROGAMS and selecting Acer Empowering Technology and then Acer recovery Management.
This might differ a little because you have a netbook
Nov 07, 2010 | Acer Aspire 3000 Notebook
Acer aspire one mini notebook. NTLDR is missing.. no bootable device--insert boot disk and press any key
If you don't have documents, pictures, etc on the hard drive that you need to backup, try running system recovery by doing the following (not sure if this works on the version with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
Oct 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have acer aspire trying reinstall windows xp?
Put the disk in,restart computer and tap F12 while it is starting up.
May 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One 11.6" 722-0432 Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
