Question about Kenmore Elite 45986 Front Load Washer
A technician once told me to run my Kenmore Elite 3t ( without clothing ) with some bleach to clean the machine on the inside. I do not have a "clean machine" cycle. However I don't remember how much bleach to use or if he said to use vinegar. I purchased this washer back in 2003. thanks
  • Kenmore Master
  • 3,463 Answers
Most of the major manufactures recommend that you do a hot wash with the normal amount of powder or detergent in, but without clothes through a full cycle..
It is referred to as a Maintenance wash, and should be done about 3 or 4 times a year, depending on how often you wash.
This helps to keep the interior drum and other parts clean, and prevent smells and build up of slime etc.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
  • 242 Answers
Hello , pour the bleach into where the soap would go [about 2 cups], then fill your softner and bleach containers up as well , run a normal wash with an extra rinse , the bleach will not hurt it so the more the better but to a certain point. this should fix alot of the noticible mildew but to get it all use a brush and scrub with bleach.
Phil
I've been noticing what appears to be a rust stain on white shirts that come out of a Kenmore 3t front loading dryer. They are all the same shape, a 3 inch stripe.
i would inspect the drum, and take some white towels soak them in bleach, wring them out and run them through a cycle and see if that cleans it up. Hope This helps Tim
Oct 24, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer smells
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap.
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t Washer - Bleach Dispenser Issues
The Sears repair man told me that I was filling the bleach and fabric softener too high and when you close the tray is splashes over and runs into the drum. Not all of it runs out though just the portion that goes over the Fill Line.
Jun 26, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
Kenmore elite he5t washer
I too have a HE4t washer. When I bought it, the Sears sales man said that after doing the wash for the day, you have to always wipe out the insides of the rubber gasket. If you do not do this, you will get mold build up. I an anal about doing this and for 6 months now have had no mildew smell. However, I went on a trip for 2 weeks and when I got back, there was an awful mold smell. I checked the gasket and sure enough, there was gunk build up. Needless to say hubby and kids did not do the maintenance. I had to wipe it up several times with bleach to remove the mold spores. Then I ran a sanitary cycle with pure bleach. Smell is gone thankfully.
But don't you think it's ironic to have a $1500.00 machine that needs to be babied after the end of the day?
Oct 17, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
158 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
