Question about Motorola Mobility S305 Bluetooth Headset
Pair Motorola S305 Bluetooth Headset with windows 7 laptop
map9966
  • 2351 Answers
SOURCE: maual for Motorola H350 bluetooth headset
This may help. Click the link:
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/AU-EN/H350_User_Manual_19oct2007.pdf
Ignore the chinese as you go. Its like mixed together but you'll find what you need. Good day!
Please vote.......
Posted on Jan 17, 2008
rockfixya
  • 679 Answers
SOURCE: motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 22, 2009
timthorne911
  • 464 Answers
SOURCE: pairing ny bluetooth headset with cellphone
it's always 0000
Posted on Mar 18, 2009
zohail
  • 1223 Answers
SOURCE: have motorola h710 bluetooth headset and no
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Posted on May 03, 2009
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
Pairing to panasonic
Put your S305 in pairing mode and then have your Panasonic search for the Headset.
https://www.motorola.com/moto_care/manuals/S305_QSG.pdf
Mark
Motorola Support
Jun 12, 2014 | Motorola Mobility S305 Bluetooth Headset
Cannot pair S305 to iPad 2
If you have the headset paired w/ another device, you have to "forget" it on that device and then try to pair w/ the iPad.
I was having the same issue w/ new iPhone 4, but this solved it for me. It is a bit annoying to have to forget and unpair every time you want to switch devices, but oh well.
Apr 02, 2011 | Motorola Mobility S305 Bluetooth Headset
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
H350 does not work as audio device
I was able to use my Motorola H350 Bluetooth Headset on Windows 7 by installing the drivers found in this link: http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Good luck! It took me about a week to find the solution.
Aug 20, 2009 | Motorola Mobility H350 Wireless Headset
Pairing H710 to a computer
Well. This is probably not a solution you guys want to hear, but it just worked. I left it for months, maybe it was just the time, or a recharge needed to wipe out one of the paired devices in memory, but it just paired with my laptop like that. Used it for while too with Skype.
I am also using the new Windows Seven RC this time around, maybe it was a Beta issue, that got fixed with the RC.
Feb 11, 2009 | Motorola Mobility H710 Bluetooth Headset
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility S305 Bluetooth Headset Logo
539 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
