Question about Hasbro Furreal Friends Lulu My Cuddlin Kitty Cat White
Batteries rotted ths springs on the LULU battery cover.
I need a replacement battery cover with the springs attached.
Can the battery case cover of an Olympus SP550 uz be easily obtained & easily replaced?
The cover on the camera is cracked or the battery case is cracked. If it is the battery that is cracked replace it immediately. If its the camera attachment that is cracked Gorilla Tape works wonders :)
DO NOT USE THE PHONE IF THE BATTERY CASE IS CRACKED!
Sep 13, 2014 | Olympus SP-550 UZ Digital Camera
Lulu cat battery door
Try ebay people always sell spare parts.
Dec 24, 2013 | Hasbro Furreal Kitty Cat
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
Need replacement lid for battery cover of Fur real Lulu cat
Try ebay sometimes they sell speare parts. It is a common thing to loose unfortunately.
Nov 09, 2013 | Hasbro Furreal Kitty Cat
Battery cover for fur real cat
Try ebay. It is common unfortunately.
Nov 09, 2013 | Hasbro Toys
Replace a Radiator
disconnect , battery neg, term , so aunt Lulu dont try to drive dry car.
drain all coolant, (petcock valve , open)
remove fan wires, and all hoses. and attachments to rad.
unbolt rad, some have 4 bolts on sides, and some have only top
hold down screws. (looking works)
and if A/T tranny car , rmove the tranny cooler lines.
once its free of intanglements, you un clamp it from the body and
it comes out. (up)
why not log in to alldata.com and read the 25 steps.
log in and read.
its all there.
Sep 22, 2013 | 2004 Acura MDX
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Dec 05, 2006 | Kodak EasyShare CX7430 Digital Camera
Hasbro Furreal Friends Lulu My Cuddlin Kitty Cat White Logo
27 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
