Question about Lenovo Ibm Thinkcentre M55e 9645-c65 Parts
Thinkcentre M55 9645 CPU upgrade - Lenovo Ibm Thinkcentre M55e 9645-c65 Parts
I want bios update my IBM Lenovo 7298 pc
Hi
If you go to the page below there are many options for installing a BIOS update.
Desktops and all in ones ThinkCentre Series desktops ThinkCentre M58e...
There are also various utilities to help you upgrade the BIOS, including one for upgrading from within Windows. You should make sure that you have a full backup of your data and programmes before you start. Please make sure that the version here is an upgrade compared with your current version and that you read the instructions very carefully and are comfortable with them as incorrectly upgrading, or interrupting the upgrade can lead to your machine refusing to boot at all from anything. Please be careful.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 16, 2015 | Lenovo ThinkCentre M58e 7298 Core Duo...
Want to upgrade 3.2 cpu
Go to IBM's website. All information is there.
Mar 21, 2014 | IBM ThinkCentre M51 PC Desktop
Thinkcentre A62 cpu upgrade
if ur going for a cpu upgrade better u should also go for a am3 socket mother board that will be better if u concerned with pwerformance.
Jan 05, 2014 | IBM ThinkCentre M51 PC Desktop
Ibm thinkcentre cpu fan runs on high after shutdown
Open the Control Panel. Power Options, Change/Adjust power off settings, change Sleep and Hibernate to Never, set to High Performance. A reboot everyday will reset your computer.
Jan 18, 2013 | Computers & Internet
Is IBM ThinkCentre A51 81377JG compatible with core i3 processor?
I would say no. If you do a search of your Motherboard you it will give the options of the CPU that are compatible with that Motherboard. If you have never Upgraded a CPU it takes a bit of research. You Mobo shows these options for CPU: http://support.lenovo.com/en_US/product-and-parts/detail.page?LegacyDocID=MIGR-59211
Nov 30, 2012 | Computers & Internet
What`s the maximum processor upgrade for IBM ThinkCentre M51?
MAXIMUM CPU FOR IBM M51 = Pentium 4 650
3,40 GHZ / 2M CACHE / FSB 800 / HT / SOCKET 775 ( SL7Z7 or SL8Q5 ) they take 84 Watt, by the way, change the power supply,with connections for Pcie x16 graph-cards ,like 800 Watt. HD cards are not supportet, Max.- card is ATI x1950 Pcie x16 512MB. Do not try the ATI 5450 will not work.
Processors:
DO NOT THINK ABAUT THE P4, 651 / 660 / or 661 ,will not work .( multiplier is 17 ) and not supportet by the mainboard and chipset.
Nov 20, 2010 | IBM ThinkCentre M51 PC Desktop
I have an IBM thinkcentre m51 that I am trying to upgrade to a dual core processor. It seems that it won't take it. Is there a setting on the bios that will allow the motherboard to support a dual core...
Most major manufactures use motherboard designed to their specs and upgrades to the processor are limited. You can use software such as Belarc Advisor, to determine what motherboard you have and then you can search the net to determine what processors are compatible with it.
Nov 08, 2009 | IBM ThinkCentre M51 PC Desktop
I have a problem in Lenovo/IBM ThinkCentre A51 8135-41G when power on the cpu fan start in hight speed and hung what can i do
open case and see if the fan is dirty, clean it with canned air if that solves the problem your set. If it doesnt solve your problem then the Fan will have to be replaced ,in order to keep the cpu cool.
Jul 12, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
What is the best cpu to go in to a lenovo bora-rh mobo?
Goto http://www,crucial.com
Click on - free memory scan - allow the activex control to install if prompted. The program will perform a quick scan of you system and provide you with reccomended compatible memory options. Crucial is who I use and they have a no fuss retun policy.
Also, for CPU upgrades - checkout http://www.pricewatch.com - Ultimately you have to make the decsion - cost vs. performance - Good Luck - Hope this helps
Mar 16, 2009 | IBM ThinkCentre A51 PC Desktop
Lenovo Ibm Thinkcentre M55e 9645-c65 Parts Logo
78 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
