Question about ASUS A52f-xe4 15.6" 2.13ghz 4gb 320gb Notebook
F9 doesnt work on asus a52f just says windows 7
I think i have the google redirect virus...just want to reset to factory setting...no backup disk
  • ASUS Master
  • 27,725 Answers
You might try the Delete or all the F function keys also some computers use cntrl +alt +delete
http://download.cnet.com/%7Bvalue=http://www.download.com/keyfinder-thing/3000-2094_4-10491989.html Finding lost application install keys is quick and simple with this handy executable, a complete rewrite of a well-received earlier version.
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer." If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option. g) At the DOS prompt type the following three commands: bootrec.exe /fixmbr bootrec.exe /fixboot (may return an 'Eliment not found' message) bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
Hope this helps. Keyfinder Thing's simple, easy-to-understand interface has Wizard-like efficiency. This application quickly scans your system registry for 90 supported software titles and displays product names and icons in the result window. Single-button clicks copy all keys to either a text or HTML file. b> http://download.cnet.com/product-key-finder/3000-2094_4-10694022.html Product Key Finder is a single function utility that executes in a GUI, but displays a Command window result. You merely double-click it to display the 25 character Microsoft Windows Product Key. then store it away for safe keeping not on your computer
Posted on Dec 08, 2012
SOURCE: Asus eee pc 900HD running XP. need to restore to
OK, here is what you need to do, you need to get a USB - DVD dongle, either SATA or IDE. Similar to this at this link. http://cgi.ebay.com/USB-2-0-TO-SATA-IDE-ADAPTER-CABLE-4-DVD-CD-HARD-DRIVE_W0QQitemZ220544495390QQcmdZViewItemQQptZLH_DefaultDomain_2?hash=item335979ef1e#ht_4098wt_1152 Get your recovery DVD, put it into the DVD. Then, set the eeepc to "BOOT" from removeable media. The PC should then boot of the DVD and you can then install OR repair the install. I have included a link that gives you a step by step. http://www.sampletheweb.com/2008/01/05/installing-windows-xp-on-the-asus-eee-pc/
Posted on Jan 22, 2010
  • 162 Answers
SOURCE: How can i get Asus Eee PC back to factory settings?
Hi. Actually when you restore your system to its factory settings it will restore everything on your computer including the original operating system, but if you're saying that you have installed windows 7 on it then try going to ASUS driver support website, just type in their the model of your machine and it will ouput every software and drivers available for laptop and also different versions of operating system, So just choose the correct OS version for your laptop. Hope this Helps
Posted on Jun 04, 2010
mrninja
  • 600 Answers
SOURCE: i want to recover my
You have to disable "boot booster" in the BIOS first....then as soon as you turn on the power start to press the F9 key about every second.. and click the check mark to start system recovery
Posted on Dec 27, 2010
  • 38 Answers
SOURCE: following instructions for factory settings on
ASUS netbooks have a Boot Booster which renders all activity obsolete, you need to disable the boot booster first.
First you need to access the BIOS/Setup Utility, on an ASUS machine/Motherboard you need to hit "Del" or "F2" not F9 at this stage.
Once in the Setup Utility, using your arrow keys navigate to the Boot options page. Using down arrow key navigate to Boot Booster option and hit Enter to disable. Once the option is disabled navigate to the last tab Exit, and using down arrow key to navigate to Exit and Save Changes.
Your laptop will then reboot and as soon as it does you may start to hit "F9" which will start the Factory Settings utility. You can then follow the on screen instructions to continue wit the resetting of your machine.
Posted on Jan 13, 2011
  • 64 Answers
SOURCE: f9 wont help to restore
Use System Restore.
Open System Restore by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, clickingAccessories, clicking System Tools, and then clicking System Restore.
18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Choose the first system restore point to restore factory settings.
http://windows.microsoft.com/en-US/windows-vista/What-is-System-Restore
Posted on Feb 02, 2011
Asus g2s
Did you do ALL your windows update before the Service Pack? That SP has been out for years? Doesn't your laptop have Windows Updates set to Auto? Choose one or the other, Vista or Win 7 and do a Full Install.
May 09, 2013 | ASUS Computers & Internet
How do i reset my laptop to factory settings
You will need your recovory disk or a OEM Windows CD ROM (windows XP,Vista, Windows 7)
  • 1
    Restart your ASUS laptop and press the "F9" key while the computer is booting up. This will open the boot screen. Select "Recover Windows to Entire HD" and press "Enter."
  • 2
    Press "Y" three times when asked if you are sure that you want to restore. The laptop will restore the factory settings. The computer will then shut down and start up again.
  • Sponsored Links
  • 3
    Approve the license agreement, then select your "Language preference." Enter your name into the box and click "Next."
  • 4
    Enter your password twice on the next screen and select "Next." Enter the time zone and date information, then select "Next." Select "Finish" on the next screen and the computer will reboot.
  • Aug 17, 2012 | ASUS Computers & Internet
    Asus computer freezing up
    Windows vista is a large operational system that caused the very complaints that people were talking about and that is why window 7 came in because it is lighter and faster and takes less resources. But to address your problem sub out the ram memory one at a time to see if there is a difference, quite often reseating the ram will sometimes fix the problem.
    Jun 04, 2012 | ASUS Computers & Internet
    I didn't make a copy of windows 7 starter or restore point from my asus eee 1015 pe. Now I have system problems and I don't now how to recovery my computer to the factory settings. I was trayed...
    If you can boot into Windows 7, Open Backup and Restore by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Backup and Restore.
    In the left pane, click Create a system repair disc, and then follow the steps. Administrator permission required If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    If you cannot boot up, you can do the above process on any Windows 7 PC. You will need a usb flash drive or a blank CD or DVD to create the repair disk.
    Sep 28, 2017 | ASUS Eee PC 1015PE
    Hi i have a asus 2gb surf and it wont pick up windows i tried the f9 reboot but it doesnt work, whats the best way for me to get it back to original factory state, i do not have the recovery CD im not sure...
    Best ways would be the following
    • Contact Asus for the recovery disc OR
    • Google TinyXP and install that. It's basically a highly modified version of XP that is very small and a good idea for a surf. Only takes up about 390MB of space.
    Comment back if you need anymore help.
    Sep 17, 2011 | ASUS Eee PC 2G Surf Notebook
    How do i reset my 2g surf back to factory settings
    You can download a windows password reset tool and create a windows password reset disk with it. Few days ago I downloaded a program named Windows Password Reset 9.0 and I successfully reset the forgotten password with the disk.
    Oct 19, 2010 | ASUS Computers & Internet
    Want to reset my daughters eeepc to factory setting tryed pressing f9 but nothing is happening can u plz help is their any other way thanking nu
    press f2 disable the booster boot
    if still nothing, try all f keys, tab and space bar also have default settings on some
    last is install windows xp on a usb flash drive if you dont have the dvd /cd restore disk
    Sep 17, 2010 | ASUS Eee PC 900 Notebook
    I want to reset it
    Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
    Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
    Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
    Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
    Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
    Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
    Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
    If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
    http://www.vtechsquad.com/acer-support/
    Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
    When I type on my ASUS U50A notebook, the cursor jumps ahead and behind, especially when I'm tying the letter "o". How do I fix it?
    Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem.
    We are committed to supply a variety of laptop parts for fulfilling your needs.
    <a href="Asus'>http://www.laptopparttips.info/2012/09/09/asus-n53sv-keyboard/">Asus N53SV Keyboard</a>,
    <a href="Asus'>http://www.laptopparteshop.com/asus-n53sv-keyboard-replace.html">Asus N53SV Laptop Keyboard</a>,
    <a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus G60jx White Keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-g60jx-keyboard-replacement.html">asus g60jx black keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-g60jx-cpu-fan-replacement.html">asus g60jx laptop fan</a>,
    <a href="replace'>http://www.laptopparttips.info/2012/09/09/how-to-replace-fan/">replace cpu cooling fan</a>,
    <a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus g53 keyboard</a>,
    <a href="Asus'>http://www.laptopparteshop.com/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&q=asus+a52f&cid=0">Asus A52f laptop Part</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-lcd-cable-replacement.html">asus a52f lcd cable</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-keyboard-replace.html">asus a52f keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-battery-replacement.html">asus a52f battery</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-cpu-fan-replcement.html">asus a52f laptop fan</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-a52-white-keyboard-replace.html">asus a52 keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-k53-keyboard-replace.html">asus k53 keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-k53-lcd-hinges-replacement.html">asus k53 lcd hinges</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-k53s-cpu-fan-replacement.html">asus k53s cpu fan</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-k53s-lcd-cable-replacment.html">asus k53s lcd cable</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-u50-keyboard-replace.html">asus u50f Keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-g73jw-g73s-keyboard-replace.html">asus g73 black keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-g73-white-keyboard-replacement.html">asus g73 white keyboard</a>,
    <a href="asus'>http://www.laptopparteshop.com/asus-u50f-u50a-keyboard-replace.html">asus u50a keyboard</a>
    Mar 24, 2010 | ASUS Computers & Internet
    Asus computer password reset.
    To unlock a forgotten Windows password on Asus, there are several free methods:
    1. With another admin account.
    2. With Windows password reset disk.
    3. From Safe Mode.
    4. With CMD.
    5. Using "lusrmgr.msc"
    More details you can found on other sites, it is easy to find.
    Another tip: Unlock forgotten Windows password with Windows Password Recovery Tool.
    1. Install this program on another computer and create a password recovery disk with USB
    2. Insert the disk to your laptop and set your laptop to boot from it.
    3. All user accounts will be loaded, then you can reset any user password.
    Apr 02, 2009 | ASUS Eee PC 900 PC Notebook
    ASUS A52f-xe4 15.6" 2.13ghz 4gb 320gb Notebook Logo
    372 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
