Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire ftfb4000fs1 front load washer will not spin
I have this front load washer that will not spin. I goes thru all the cycles fine untill it get to the spin cycle. How do I check for codes. and what is the most commond trouble? Is there a repair manual that i can download anywhere?
Thanks for anyhelp you can be!!
  • mickeycox265 Jan 17, 2009
    Thanks for the help but I found the trouble on another sight. It was the door lock wax motor. I just remover the front panel and relaced the latch assy. you can get just the wax motor.
    thanks Mickey
  • Frigidaire Master
  • 1,527 Answers
Hello **** theres a circuit board on the back or on the side called a module this controls the spin cycle there could be dry joints on the board or component may have fail good luck
Posted on Jan 14, 2009
I have the ATR6700FS1 front load washer. It goes fine until the spin cycle. It pauses & when I hit restart it makes a noise & doesn't spin. If I hit cancel & go to the spin cycle it
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 29, 2013 | Frigidaire ATF6000ES Front Load Washer
Front loading model #FTFB4000FS1 is not draining....have to run the drain/spin a second time to get the water out....where i s the filter?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 13, 2011 | Frigidaire Washing Machines
Model #ftfb4000fs1 frigidaire front load washer will not go into final spin --- drains but will not spin dry
Just had this problem last week. The problem was the door switch, which made no sense to me since the drum still turned on the other cycles. But the repair shop replaced the ($76!) switch and the machine now works fine.
Oct 21, 2010 | Frigidaire ATF6000ES Front Load Washer
ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Aug 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Jun 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load washer isn't spinning out
The first thing to check is if the door is locking. Put the unit into spin turn unit on let it go for about a minute then shut it off, try to open the door right after you shut it off if the door opens you need a door switch if not chances are you need a motor control board. Before replacing the board call for service they are expensive if it is a guess. good luck
Dec 26, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
505 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
