Question about Infinity BASSLINK Car Subwoofer
Im a tech guys who know the basic so i have basslink infinity but is not sound at all but the light on i take the lid off to check the speaker inside if is blow nut not the speaker is fine so may be something at the motherboard
  • 46 Answers
Or it could be your RCA's or the outputs on the deck...the go out quite often
Posted on Jan 14, 2009
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Infinity Basslink not producing any sound. Green light on.
check that fusse under the hood if its blown pull it out and replace it wont hurt anything if u pull it out an put it back in if the cars off.but if ur getting power lights on the amps then more then likely ur fuse isnt blown.id start by checking the audio cables are produceing sound.if u need more help let me know bertman285@hotmail.com
Sep 29, 2009 | Infinity BASSLINK Car Subwoofer
Basslink red light on but no sound
check the all power lines and regulator .is any of them overheating?
then check the power amp ic or transistors.
nuwan.
Jan 12, 2009 | Infinity BASSLINK Car Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Mar 09, 2008 | Infinity BASSLINK Car Subwoofer
No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Feb 02, 2008 | Infinity BASSLINK Car Subwoofer
Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
Jan 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink "Motorboating"
Good evening, my name is Colmen here is a guy that might be able to help you 917 504 0461 please let me know how you make out, he has done a lot for me, by the way his name is Cee...
Dec 19, 2007 | Infinity BASSLINK Car Subwoofer
Basslink II problem running off speaker input
Definately a wiring issue. Go to this site and backtrack to see where you went wrong. hope it helps.
http://www.ehow.com/how_5829_wire-car-stereo.html
Dec 12, 2007 | Infinity BassLink II Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
269 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
