Question about Belling XOU252 Electric Single Oven
Broken cooking appliance :( please help
Belling XOU 252 electric oven I have all functions working on my appliance other than the fan assisted section on my oven,(which means I can't cook!) Does this mean I have a heating element that has blown or something else? Many thanks in advance Peter J Roscoe (uk)
  • 1 more comment
  • Anonymous Mar 15, 2014
    how old are belling oven xou 178ss
  • Anonymous Mar 29, 2014
    There is no display in the timer section. That means, that I cannot use the oven for auto cooking or setting the timer
    Sergeant:
  • 236 Answers
If the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Posted on Jun 11, 2007
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
Oven not heating up [fan works] the oven is a belling xou 163 the grill works but the oven does not warm up
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 11, 2010 | Belling XOU252 Electric Single Oven
No Power to Belling 163 model
check the safty cut out, if there is one
May 16, 2009 | Belling XOU252 Electric Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Belling oven xou 179
Hi
you need to remove back panel in oven. from there you will see the element somtimes you can unscrew them from inside if not you will have to remove oven from housing . remove back panel and the element will be bolt from behind just remove these the refitt new element in reverse order. hope this helps you
regards dan
May 19, 2008 | Belling XOU174 Electric Single Oven
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Belling XOU252 Electric Single Oven Logo
255 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Mike Charette
Are you a Belling Oven Expert? Answer questions, earn points and help others
