Question about Lighting & Lamps for Ford Taurus X
I can't get rear brake lights to turn off.
    Top Expert:
  • Ford Master
  • 21,873 Answers
Usually a sign the brake light switch is stuck or broken.
Posted on Dec 09, 2012
  • Richard Warren
    Richard Warren Jul 25, 2014
    brake light switch loose.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Why aren't hazard lights or brake lights working?
Brake lights /rear hazard lights not working - Ford Truck ...
www.ford-trucks.com > ... > 1967 - 1972 F-100 & Larger F-Series Trucks
Jul 9, 2010 - After checking the brake lights I tried the emergency flashers and found that they are working in the front but not in the back. I do have rear turn ... 1995 F350 Brake Lights / Turn Signals not working
Jul 9, 2012
Turn Signals and Brake Lights Do Not Work
Mar 10, 2012
Turn Signal, Brake Lights, & Rear Hazard not working
Aug 3, 2010
Rear Turn Signals, Hazards and Brake Lights not working....
Aug 29, 200
Sep 30, 2015 | Cars & Trucks
Nissan Xterra Brake Light Fuse Location
It's 15A FUSE 39 in the fuse & fusible link box
Mar 25, 2017 | Nissan Xterra Cars & Trucks
Hi, you need to test if the power is coming to the plug for rear brake light. If the power is not there that is your first problems. Also may have earth wire problem.
Jul 20, 2013 | Nissan Xterra Cars & Trucks
Front & Rear turn signal
Not familiar with the Softail Rocker, but the 2009 Baggers have a "Turn Signal Security Module" (TSSM) as one unit.
This is what it looks like:
http://img.photobucket.com/albums/v312/Bulldogxj/Picture001-1.jpg
Mine is under the seat.
Jun 19, 2013 | 2009 Harley Davidson FXCW Softail Rocker
2004 right rear tail light/ brake light not working
these may not work unless the vehicle is running as leds require a certain amount of power to work..also check the ground wires..turn on 4 way flashers and see what the lights do.. repost..
Jan 30, 2013 | 2004 Cadillac Escalade
2003 dodge durango all brake lights not working
Check to see if the brake light switch under the dash at the brake pedal is bad before you go too much further.
Sep 15, 2017 | 2003 Dodge Durango
No turn signals, 1 driver brake light bad, ABS light on. 2002/2003 CVPI
Sounds like you have 'ground' issues. Apply the brakes using a broom stick or more apropriate tool so that the brake lights are activated. Then go to the brake light that is not bright enough. using a test-light with a sharp pointed probe, poke the ground wire close to the bulb (usually a black wire) make sure the test light is attached to a grounded bolt. if the brake light gets brighter with ground added, you need a new ground wire. Splice it in to the existing wire & attach it to a bolt. Lights should work better with proper ground. (each bulb has a positive post & neg. post, don't add ground to the side with power coming through it from Battery (+)(red light on test light) - probe wires FIRST with test light to find (+) POS. Hot wire, and leave that one alone.
Aug 09, 2012 | 2003 Ford Crown Victoria
My ABS/Brake light in dashboard is on .
I didn't have that issue,but I had a 1992 dakota with
rear abs only & I just unplugged the module under the dash
I'm all for diagnosing everything & having it factory stock & working
But you don't need abs on a 4x4 that old & the rear hydraulic
abs unit ,gets so rusty that it is sad.
If you ever replace rusted brake tubing, remove it
They don't check that in inspection
Jun 06, 2012 | 1999 Dodge Ram
Brake light does not work when brake is engauged
You have two brake light switches, one for the rear brake and one for the front brake. If neither switch turns the brake light on, the first thing to check is the bulb. If the bulb is good, check the socket and the wiring to it.
If all that is good, find the rear brake master cylinder. Follow the metal tube coming out of it going to the rear brake. Underneath the bike, there is a pressure switch that turns on the rear brake light. Check to make sure the wires are connected and that one set of wires is "hot" when the ignition switch is in the "ON" position. If so, the switch is probably bad. Replace the switch. I have seen them check good with a meter but still not turn on the brake light. Work with the rear brake light switch first as it's the easiest and least expensive to fix. When you get that working, repost and I'll take you through replacing the front brake light switch. It's quite a bit more difficult to replace than the rear switch. I'm sure that procedure is in the archives as well because I've posted it a number of times.
Good Luck
Steve.
Apr 30, 2011 | Harley Davidson XLH Sportster 883 Hugger...
Lighting & Lamps for Ford Taurus X Logo
51 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
