Question about Dell 1320c Laser Printer
Black is faint. All other colors good. Dell 1320C
I have replaced the toner cartridge with a Dell Cartridge but there is no difference. It appears that the toner is there but not much is getting onto the paper for black only.
  • 11 more comments
  • cscoxk Jan 12, 2009
    When I look further it appears it is mainly in the printed letters. Diagrams with black parts appear almost solid although they are little mottled whereas the print quality for black is very faint and grey Printing in color is good.
    I cannot find a calibration test? I have been looking for something that might "clean" the machine but there does not appear to be such a program. The only thing I can find are is the toolbox for the printer but it does not appear to have a calibration program.
    This is a laser printer not an inkjet so I would have thought it unlikely to have the same ink type problems as inkjets. The quality of the printing is the same. It almost appears as though the print settings for black are set to faint - if there is such a thing - but I have been unable to find such a setting.
    When I first received the printer it printed well. I have tried 2 new black toner cartridges but I think the old one has toner in it.
  • cscoxk Jan 14, 2009
    Anyone any other ideas on how this can be fixed or indeed if it is possible. The annoying thing is the purchase of two cartridges that cost about the same as buying a new printer. I will certainly be much more careful about buying anything from Dell. I have tried calling Dell help but they suggested I buy another cartridge!!!
    As mentioned it is a laser printer not an inkjet printer so the suggestion does not apply.
    Question is making faint black printing on Dell color laser printer darker. Cartridge replaced. Colors print well. Only black text is the problem.
  • johnnyheaven Mar 17, 2009
    Same Issue with three of these printers now. Color is Ok but not great and the black is faint. Almost as it is in a "draft" mode except it was never set.
    Multiple toner changes have not given any improvement. Printer was working fine when new.
  • katie366 Mar 31, 2009
    I have only printed 400 pages since I bought my printer (2 months ago) and since I have replaced the black cartridge with a new one from dell, I have very faint grey text. I have e-mailed dell 2 weeks ago for support and still heard nothing.
  • Anonymous Apr 30, 2009
    Print Cartridge not registering, slot damaged, does anyone know of a parts store for Dell 1320 printer parts.
  • Anonymous May 06, 2009
    Exactly the same as the problem reported by 3 people -- my DELL 1320 arrived and printed OK 900+ pages, then it started to print just the black parts of a page very faint (grey).
    I bought an expensive replacement toner cartridge, thinking it was running out of black, but the problem persists...
    It seems a design fault. Oh dear, DELL will never admit to that...
  • nicolas May 07, 2013
    same for me. Dell is a shame
  • Anonymous Mar 24, 2014
    Dell 1320c belt unit has large scratch across it, how do I replace?
I have just got around this issue by going into the printer properties, click the "Printing Properties" button, click the "Printer Status" button, go to the "Printer Settings" screen select the "Printer Maintenance" tab, select the "Non-Dell Toner", tick the Non-Dell Toner box and click the "Restart printer to apply new settings" button. Print a test and then reverse the process.
Posted on Sep 08, 2009
  • 1 more comment
  • Carole Meyrick Jun 22, 2011
    Thank you! It worked perfectly after I'd tried all sorts of other things including air cleaning the PHD unit etc. I was beginning to think I would have to buy another printer, but your solution sorted the problem.
  • mariahcountr
    mariahcountr Dec 30, 2012
    Thank you! Out of the blue, in the middle of a christmas gift project, red decided to not print. I tried many things to no avail. I started to shop for a new color laser printer when I found your suggestion and it worked! My Dell 1320c is printing red again! Yay!
  • Billie Belen Aug 27, 2013
    when I hit Printer Status, it gave a warning PRINTER MONITOR not installed.. how do i fix this? I have the faded black issue.
  • 4 Answers
This isn't a fault with the printer, IT IS A FAULT WITH THE WAY IT HAS BEEN SET UP!
The problem is, not all of the tabs have been removed from the PHD unit inside. In order to remove these, you need to open the front cover of the printer, move the four tabs 90 degrees and pull the whole PHD out. You will then see the four yellow tags on the side.
Having printed with the tags in means the PHD has been potentally damaged. If you're lucky, you'll get away with removing the tags now and it will return to normal after about 50 pages, it not then you'll need a new PHD. The reason the problem manifests itself with black first is because the black is the most commonly used colour.
For info on removing all the tags, see here:
http://support.euro.dell.com/support/edocs/systems/prn1320c/en/ug/1320c_en/section04.htm#1055182
Posted on Oct 03, 2010
  • 916 Answers
Toner trimmer blade inside Imaging Unit gets worn. You need to replace the imaging unit and the problem will go away.
Posted on Jan 14, 2009
  • 55 Answers
I'm not sure if this will help you but this is a guide from dell on improving faint printing. It's worth giving it a try: http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=ca&cs=cahied1&dl=false&l=en&s=hied&docid=3B72A6DD0C6ED785E040A68F5B28594B&doclang=en
    New Friend:
I've had the grey problem along with a groaning squeak for a while now. Tried everything while printing one page of graph paper at a time then resetting if it didn't work. I got a very slight improvement after switching on toner saving mode, printing 1 copy then setting it back to off. The big improvement came when i changed altitude in the settings to 3000m. It took a while for the machine to reset but the improvement was immediate and back to it's former excellent output. Printed one sheet, set it back to 2000m, then 1000m and finally back to sea level with no detrimental effect on the output.
Best of all it has cured the really annoying squeak!
Hope this helps somebody else.
Posted on Apr 10, 2014
I have an idea what's wrong, if anyone is still following this thread. I realised that I get these stupid faint prints when my 1320c doesn't seem to take the proper amount of time heating up. Can't do anything about it, but leave it to stand by and starting it up again, hoping it would go into the process of heating up properly.
Not very technical, but this is what I've observed. Annoys me like crazy when it happens.
Posted on Jul 02, 2009
    Problem Solver:
  • 9 Answers
I took an air compressor and blew out everything except the ink cartrage. The first time I cleaned it out I blew off the base unit with the mirrors. These are talked about alot on the internet. This did not help much because the mirrors where clean already. Then I took the PHD unit out and blew the hell out of it and alot of ink dust came out. I kept blowing it out untill no more ink came out and everything was clean. Be carrful not to touch the rollers with your fingers. It helped alot. Good luck and Happy New YEAR!!!!
Posted on Jan 01, 2011
  • 10,515 Answers
Dude, u r absolutely correct....This is a major concern for all the users of Dell 1320c Laser printer.....
however, we need to stick with basics :(
Possibilities
1) Faulty toners - but 3 of them (tried 2 toners in 1 printer) ?
2) Faulty PHD - but again - in 2 printers??
3) Faulty Printers?
Have removed all the yellow tabs that I can find and tried adjusting various settings both on teh printer and the software to no avail..
Only solution has been to ask people to try changing text to say blue but this is not ideal and getting very frustrating for all.............
take Care.
Posted on Jan 12, 2009
    Genius:
  • 1,269 Answers
Have you tried the calibration test using the printer utility? It will try to clean excess ink that are stored or dried.
  • 80 Answers
Try to reinstall the drivers, or run a maintence routine with the software that came with the printer. It should allow you to clean the heads. It is worth a try.
    Genius:
  • 1,199 Answers
Clean the print head for black and than try again it should work if not Try reinstalling the software!
    Sergeant:
    Champion:
  • 275 Answers
Error code 093-921
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Mar 02, 2016 | Dell 3130cn Color Laser Printer
The left side of paper comes out of my Dell 1320c printer very faint. Why?
If there is a toner cartridge in this printer, take it out and shake it. Do this outdoors in the event that come toner comes out in the process. Don't want to soil carpeting with toner! Sometimes the toner clumps up and doesn't spread throughout the cartridge. Shaking it, distributes the toner and allows printing more evenly.
Jan 08, 2015 | Dell 1320c Laser Printer
My Dell 1320c printer toner light won't stop blinking
this will sound dumb, make sure you remove all the shipping materials from the cartridge including anything that may be over the electronic components to let the printer identify the new cartridge.
Apr 03, 2012 | Dell 1320c Laser Printer
Black toner is gray after installing new toner cartridge
If the black has been noticeably "lighter" or gray, than it is time to replace the drum unit on the machine. (usually replaces every 5-8 toners)
May 24, 2011 | Dell 1320c Laser Printer
The black print on my Dell 1320C laser printer is very light (grey) in fact. I replaced the black toner at no avail. The other colors are fine.what can I do to soulve the problem. ...
It sound like you have either a very low toner density set, which would normally be set either through the control panel or the driver, or possibly the Dell Toner conservation system turned on. Here is Dells owners manual info on dealing with light print.
The toner cartridges may be low or need to be replaced. Confirm the amount of toner in each toner cartridge.
  1. Press [Printer Status], and then click the Status tab in the printer driver.
Ensure Non-Dell Toner is not selected in the Printer Maintenance tab in the Tool Box.
  1. Click the Tool Box button.
Set Toner Saving Mode to Off in the printer driver.
  1. Press [Printing Preferences], and then click the Advanced tab.
If you are printing on an uneven print surface, change the paper type setting in the printer driver. For example, change the plain paper to thick.
  1. Press [Printing Preferences], and then click the Paper Tray tab.
Verify that the correct print media is being used.
  1. See "Print Media Sizes and Support".
Ensure that eight yellow ribbons are correctly removed from the PHD (Print Head Device) unit.
  1. See "Replacing the PHD (Print Head Device) Unit" and "Installing the PHD Unit".
Ensure that the developer motor starts.
  1. Contact Dell.
Ensure that the dispense motor starts.
  1. Contact Dell.
When you are printing many images with low density, do the Toner Refresh Mode.
  2. Press the Start button to check the density of colors.
  3. If the print is too light, Select Refresh Mode from the list. Press the Start(1)-(4) buttons.
CAUTION: Using the Refresh Mode consumes extra toner.
  1. After you complete the Refresh Mode, select Chart Print from the list. Press the Print with A4(3) or Print with Letter(C) button for 4 Colors Configuration Chart. "Printing" appears.
    Is the problem recovered?
May 06, 2011 | Dell 1320c Laser Printer
My Dell 1320c Colour Laser Printer prints black as grey. How can I get it to print black?
If you have an extra black toner cartridge, try installing that and see if it fixes the problem. If it doesn't make sure Toner Save Mode is off (in the print driver, under Preferences). If your copies still come out gray instead of black, you may need to replace the Print Head Unit (PHD).
Feb 21, 2011 | Dell 1320c Laser Printer
My printer says that the cyan toner is missing or not inserted. However it is correctly inserted and i dont know what to do.
This could be caused by a faulty cartridge, if you have another cyan toner cartridge replace the faulty one and see if this makes a difference.
Jun 09, 2010 | Dell 1320c Laser Printer
Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Dell 1320c Laser Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Dell 1320c Laser Printer Logo
7,861 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
