I have a msi tab. When I charge it was'nt charge
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Dec 09, 2012
5 Suggested Answers
Superkris
  • 9 Answers
SOURCE: Hello i have a charging problem in my Acer TravelMate 4150 model
Well, this is happening to another laptop i know. if you remove the battery and order a new one and replace it it should work. Its probably just a dodgy battery. While you have the battery out, you will need to use the power cable all the time. This just happens to some batteries. Thats just my advice anyway.
PS: I am only 99.9% sure this is the right thing to do. I would check at a computer repair place too or battery world.
Posted on Dec 22, 2008
BubbaGuru
  • 70 Answers
SOURCE: Holle
remove battery and reseat it. If problem persist, the battery may need to be replaced. Look on the laptops website to see if there was a known issude with the batteries in your series.
Posted on Mar 20, 2009
haayz
  • 197 Answers
SOURCE: HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
If you charged up your battery up for 2hrs but didnt increase the percentage or didn't charge up at all it means that your battery is faulty. I have also a same case with you.
Send it to the service center near you and ask them to rplace your battery. Replacement is free if machine is under warrant.y
Posted on Jun 03, 2009
djredskyy
  • 670 Answers
SOURCE: Hello, well my acer laptop
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
Posted on May 20, 2011
My alante power chair does not hold the charge
The new batteries or the charger could be defective
Sep 07, 2016 | Golden Technologies Health & Beauty
My lenovo s nt charging but my adapter s wrkg
If you have vibration when you hold the power button you can try this solution:
Aug 27, 2014 | Lenovo IdeaTabTM A1000 Tablet With 7in....
My tab.was'nt charge well
Dear Brother:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 05, 2012 | Cell Phones
How can i install windows 7 on a new sata ******* a msi k8n neo4 motherboard with mainboard cd?
it has nothing to do with the motherboard make sure you format the hdd before you install the OS
Jan 31, 2012 | MSI Computers & Internet
Alternator is not charging but the local parts store tested it and it is working fine, all fuses are good
what makes you think its not charging? alternators should always be checked ON THE CAR.
Aug 03, 2011 | 1999 Oldsmobile Alero
BIOS IS DAMAGE;HOW TO RESET?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart or
http://download.cnet.com/msi-kt4v-bios-windows/3000-2098_4-10162333.html
Update BIOS in your MSI KT4V motherboard for Windows 95/98/Me/NT/2000/XP.
or
Update BIOS in your MSI K7T Turbo2 motherboard for Windows 95/98/Me/NT/2000/XP.
http://download.cnet.com/msi-k7t-turbo2-bios/3000-2098_4-10162343.html
http://download.cnet.com/msi-kt3-ultra2-bios/3000-2098_4-10162341.html
hope this helps
Jul 23, 2011 | MSI NF750-G55 Motherboard
Driver msi model P4m266-8233 n1996
Check the manufacturer's "support" web-site: http://www.msi.com.tw
Select the "device-drivers" for this "vintage" computer (Pentium I or Pentium II at only 266 Mhertz), if they still are available.
What Operating System are you trying to install? Windows 95? 98? NT? 2000? XP?
Any computer built in 1996 should already have the correct device-drivers included on the Windows XP (released in 2001) CD-ROM.
Jul 13, 2011 | Computers & Internet
"Backup battery very low" message popup after
internal battery of the device is defective already, this is located inside the main board of the scanner
Feb 16, 2011 | Symbol PPT 8846
DV-DM1-VP worked a couple times now won't turn on. The battery is not holding a charge. How long should the battery be charged before using.
Sometime over nigth but try the power pack charger
to power the camera see if it work .....
battery its usely 12 hrs charge....
hope that will help
Apr 15, 2010 | VuPoint DV-DM1-VP Flash Media Camcorder
Computers & Internet Logo
David Payne
David Payne
