Maytag centennial overflowing
Overflows during wash cycle when adding cloths
Check for a hole or crack in the clear fiil tube connected to the back of the control and the bottom of the tub
Posted on Apr 24, 2013
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Posted on Oct 16, 2008
  • 6 Answers
SOURCE: top loading Maytag washing machine is overflowing
water level switch is bad
Posted on Mar 30, 2009
  • 113 Answers
SOURCE: Water won't shut off during wash/rinse cycles & overflows
the clear tube going from the tub to the pressure switch probably came undone or has a hole in it
Posted on Apr 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on May 20, 2010
tbirdfan1
  • 3051 Answers
SOURCE: My maytag washer is overflowing and won't go into
Hello there and welcome to fixya
This is a fairly common problems on these and other machines
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please feel; free to post me back any comments on repair help or testing and removal ian installation if needed ill be glad to help you ok
Best regards Mike
Posted on Apr 10, 2012
Maytag centennial washer says 2 drain is that inside or outside diameter.my washer not drain well - overflows standpipe.
if the standpipe is overflowing then the standpipe is clogged and you have to snake the line so the water will go down the pipe,it's not the washer
Oct 06, 2017 | Maytag Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Oct 16, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
