Question about managemylife.com
Garage door will not stay closed when pressing remote
  • Anonymous Mar 30, 2014
    I can't get it adjusted to stay closed. opens fine, goes down fine but will not stay closed. I have adjusted all I can to reduce down travel and close force. what can i do
Move anything on the floor near the sensors away from the sensors. also make sure the door is not hitting anything
Posted on Dec 08, 2012
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
Why won't Chamberlain 1040-6 garage door opener open or close?
In addition to the ANT suggestion, are you able to open/close the door with the button first? And then check the 12-volt battery in the remote control.
Work-around: Modern cars have the ability to learn the motor's code. Then I use the built-in openers on my cars to open the garage door as work-around. All you have to do is initiate the learning process by pressing a button on the motor, and then keep pressing your built-in opener's button until the light becomes steady. Try to let your car stay as close to the motor as possible.
Apr 27, 2014 | liftmaster Chamberlain Garage Door Opener...
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
GARAGE DOOR DOESNT CLOSE COMPLETLY UNLESS I KEEP THE BUTTON PRESSED!
There are probably two photo sensor near the ground at either side of your garage door. They are there to stop the garage door from closing if there is something in the path of the door. Likely one of the sensors got bumped or moved and it is not lining up correctly. Adjust the sensors until they line up and allow you to close the door by pressing the button on your remote once.
Jun 11, 2011 | Genie Company IntelliCode GICT390-1BL...
Garage door will not close when using the remote or garage door button. it will open, however. it can be forced closed by holding the garage door down. i have had this problem before . i have...
Check to see if your child/animal security beam is working correctly. It is an "Electric Eye" mounted about 12 in off of the floor on two mounting points and one side shoots an infra red beam across to a receiver. These points must be reasonably aligned to flash a beam (cannot see) from one point to another. This beam keeps the door open if it is interrupted . If it is not aligned, then the door opener sees a problem and will not close the door electrically. You must aligned the beam by bending the transmitter or receiver untill you can close the door by the remote. Also check to see if something placed in the garage is not blocking the beam first.
Jan 06, 2011 | liftmaster Garage Door 1/2 Hp
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
managemylife.com Logo
61 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
