Question about Epson WorkForce 600 All-In-One InkJet Printer
Rollers won't feed paper
The rollers won't pull the paper in. It just started happening out of nowhere; I can't seem to figure it out.
    New Friend:
I had a similar issue and found that a foriegn oblect had fallen into the printer and turning it upside down was able to remove it.
Posted on Dec 10, 2012
MJS_1
  • 150 Answers
SOURCE: Epson LQ-590 Matrix Printer Paper feed Problem
Assuming that you are feeding the paper into the correct end of the printer :), it seems that the printer is defective, but
First unplug the printer from the wall, wait a few minutes,
and see if it resets. If that does not work, read on.
  1. Printer rollers (and sometimes head movements as well)
    are controlled by "Stepping Motors"
    Unlike an ordinary DC motor with two wires, that spins
    clockwise or counter clockwise depending on the voltage
    polarity,
    a stepping motor contains several pairs of wires, that
    are pulsed in a controlled sequence, causing the motor
    to spin in precise angular steps. Depending on the
    number of wire pairs (poles) and internal gears, the
    stepping motor can have a resolution as course as
    90 degrees, and as fine as 0.05 degrees per step,
    depending on the cost and applications.
    Linear stepping motors can even move an object in
    a straight line.
    The benefit of these stepping motors is that, unlike a
    linear servo motor, they do not need complex positional
    feed-back for precise control, they simply step as many
    times as you tell them to. Four steps left, two steps back
    .... etc.
  2. These stepping motors are in turn driven by semiconductor switches (transistors) which are
    ultimately controlled by a central processor within the printer.
    Depending on the printer model, and how sophisticated
    the printer's internal processor is, the paper and head
    movements can be either automatically controlled by
    SOFTWARE (firmware) within the printer itself, or by the device drivers installed in Windows.
    The more self-sufficient the printer is, of course, the less
    hassle and CPU overhead on your PC.
  3. When any of the components within this chain of command fail, the stepping motor will move incorrectly:
    a) Skip steps
    b) Get stuck
    c) Oscillate back and forth
    d) Spin backwards.
  4. The causes could be:
    a) One bad wire in the ribbon connecting the motor
    to its controller board.
    b) Bad motor driver transistor: Open or shorted.
    c) Bad data line from the printer's internal control
    processor to the driver transistor array.
    d) Bad processor chip, memory or firmware within
    the printer, e.g. a burned out register or firmware
    memory location.
    e) Defective internal power supply, causing everything
    else to malfunction.
    f) Bad paper position sensor
    d) Crashed control program, which is probably the
    only thing that is fixable:
    i) unplug the printer from the wall socket, wait a
    few minutes, and see if it resets.
  5. It is also remotely (theoretically) possible, that
    the Window drivers are corrupt but this is very unlikely.
  6. If you are fairly brave and want to take the printer apart, and have some electronics knowledge and a few basic instruments, probe the roller drive motor wires, and see what gives. Is one wire stuck consistently low or high ?
    Is one of the motor windings open or shorted ?
    Is one of the driver transistors fried ?
    This very much depends on your level of skill, and the test equipment you have to work with. If you don't have a decent oscilloscope you will not get far. Without a digital multimeter you will not get anywhere at all.
Also do not forget that printers are dirt cheap, less than the ink when it runs out, so this may not be worth your time and effort.
Call the manufacturer, scream blue murder, accuse them of setting your house on fire and giving your dog diarrhea ....
and see if they will send you a freebee.
Hope this explains it.
Please rate my answers.
Martin
Posted on Jul 18, 2008
SOURCE: EPSON STYLUS PHOTO R 200
THE ROLLERS THAT PULL THE PAPER THROUGH SEEMS TO BE MESSED UP. WE HAVE TO REPEATEDLY RE-ADJUST THE PAPER, THE RED LIGHT FLASHES, OVER AND OVER AGAIN BEFORE IT FINALLY PULLS THE PAPER IN TO PRINT. ARE THE ROLLERS SHOT? DO WE NEED A NEW PRINTER?
Posted on Sep 23, 2008
SOURCE: paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Posted on Mar 24, 2009
SOURCE: printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
Posted on May 02, 2009
SOURCE: Paper won't feed into printer
I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
Posted on Jun 17, 2009
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 15, 2011 | Office Equipment & Supplies
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Jul 10, 2011 | Brother MFC-7440N Laser Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
Paper jams. Get a lot of these when running multiple prints of the same file. Paper puckers up and jams when the print heads start to draw. Have tried different vac settings and no changes
Kindly let me know the make and model of your printer alongwith what type of paper you use and also does it stucks when printing in black and what mode or color mode.
May 24, 2011 | Office Equipment & Supplies
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
Epson WorkForce 600 All-In-One InkJet Printer Logo
397 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
