Question about Whirlpool GSC9455 Top Load Washer
SLIPPING AND GRINDING
I HAVE THE LSQ9564MQ0 WASHER,[WHIRLPOOL] IT SLIPS AND MAKES A FEW CLUNK,CLUNK NOISE WHEN IT STARTS A SPIN CYCLE
  • 530 Answers
Sounds like you have a bad drive block and possibly a bad basket drive I would stop useing it before you create damage to the basket drive. take the agetator off. sometimes they have a dispenser for fabric softner take it off or it will just have a cap remove the cap with a putty knife. next you will either see a bolt 11millimeter or you will see a hole that looks like a square. remove this and pull up on the agetator to takeit of next you will see a clip it will be somwhat greasy remove it. look at the shaft you will see a nut that screws the basket down to the drive block. If the drive block is raised up off of the basket drive sometimes you can hammer it back down onto the basket drive make sure that you line the ears up female on the drive block and male on the basket drive. Before hammering back down though you have to remove the spanner nut. But if you have been useing this like this you may need a basket drive and pretty much have to rebuild the whole washer. But I would start by hammering down the drive block or replacing it. let me know thanks //eg
Posted on Jan 12, 2009
Noise starts when spin cycle starts noise increases with rpm until reaches spin speed could there be a belt slipping or what??
Belt would squeel , bearings would chatter. try a bit of hard soap on belt. If it quites down the belt is slipping
Feb 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Jul 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool type 111 cp1915409 top loader
A few things may cause a grinding noise during the spin cycle. If the washer fills normally, but when it starts to AGITATE or SPIN, it makes a noise, this is usually caused by a bad motor coupling, bad transmission, basket drive assembly, or drive motor that's starting to fail. I also wouldn't rule out the clutch. It's really hard to tell without being there to see and hear what it is doing. I would also hate to tell you to call a repairman, but it may be wise in this situation because, even if you DO know what the problem is, it may be beyond your capabilities to repair. I could give you step by step tips on how to replace the parts, but diagnosing the CORRECT one would be the challenge. I hope this helps you some. PS The likely suspect in this case would be the transmission. Not a guarantee, but a guess.
Jul 21, 2007 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal De
