Question about Frigidaire Gallery GLHS66EJSB Stainless Steel Side by Side Refrigerator
Our display says ice t3
We have 2 ice makers and neither one is making ice. The display says ICE t3?
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: ice maker not making ice
my ice maker is not making ice what could be the problem, and there is not any water in the ice machine what do i need to look for
Posted on Jan 11, 2009
SOURCE: ice maker will only make crushed ice
There is a rod on the back of the ice cube bin. It goes below a plastic slide in the back of the fridge. If yoiu pull the bin out and it does not engage right, you will be 'stuck' on crush. Pull the bin part way out and see whether the rod is going below or above the horizonal rung in the rear. If it is above, rotate the metal control until it will slip under the rung.
Posted on Apr 17, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
How do I run diagnostics on a Frigidaire Gallery Refrigerator
Ice Maker (Flex Tray Fresh Food Compartment)
The Ice Maker must be turned on before entering the
Service Mode. Check the 'ice off' indicator on the User
Interface to verify that the ice maker is in on.
Diagnostic Service Mode Activation
Express-Select ™
To activate the Ice Maker Service Diagnostic Mode,
press and hold fresh food and freezer up (?)
simultaneously for up to ten (10) seconds.
Pro-Select ™
To activate the Ice Maker Service Diagnostic Mode, press
and hold 'options' and 'power on-off' simultaneously for
Activation of Ice Maker Service Diagnostic Mode
automatically turns off all Ice Maker Control PCBA
outputs. The compressor runs at fixed speed of 4500
rpm and the condenser fan turns on until Service Mode
is deactivated. The damper is closed and the fresh food
and freezer lights are enabled as well as the alarm audio.
Defrost of the main system is not allowed.
Deactivation
Express-Select ™
To exit service mode, press and hold fresh food (?) for
up to 10 seconds.
Pro-Select ™
To exit service mode, press and hold the (+) key for up
to 10 seconds.
Service mode is also automatically deactivated after 5
minutes of no key entries (that includes Communication
Lost). All outputs are turned Off. Previously selected
main system and ice maker operational modes are
restored.
Testing
To actuate an ice maker load of the selected test step
(turn on or off), use 'power on-off' on the user interface.
To step to the next ice maker sequential test, press fresh
food (?) or '+' on the LCD screen. To step back to the
previous ice maker sequential test, press fresh food (?)
or '-' on the LCD screen. The selected test number will
be displayed on the fresh food display.
After pushing 'power on-off' to start automatic test
or turn on the load, the ice maker control will display
the test result on the freezer two digit display. When
waiting for the test to be automatically performed and
the result displayed, the test number (test ID) will flash
on/off. After the automatic test is completed the test
result will be displayed as "P" - pass, or "F" - Fail.
For an interactive test, the technician manually activates
the load using 'power on-off' and physically verifies the
system response. Pressing 'power on-off' again turns
the load off. The freezer display shows the current or
expected state of the load. During the load transition
the fresh food display flashes the test ID. After the last
test step in the ice maker test sequence is completed,
the next advancing action will scroll back around to the
first ice maker test. Stepping back from the first test, will
scroll the test sequence backwards to the last test in the
sequence.
Note: The only test that the test number will flash during
the test is the bail arm test.
Note: If you advance to another test before the present
test is completed the ice maker will continue to run until
the tray reaches the home position before the next test
will start.
Service Diagnostic Mode Test
Sequence
Test 52C: Ice maker Thermistor Test.
The current Thermistor temperature is displayed on
Freezer display when the test is started. It will show the
temperature at the ice maker if the thermistor is good.
A "OP" will be displayed for open and "SH" for in short
circuit condition of the ice maker thermistor.
Test 55C: Water Valve Test
NOTE: Prior to initiating this test, verify that the ice tray
is empty. If not, empty the ice tray to prevent water
from overflowing into the ice bucket. To empty the ice
tray, remove the ice bin, place catch pan under the ice
tray and initiate test 63C. The tray will twist and empty.
Touch 'power on-off' to start the test. The lower control
board will turn on the green and brown water solenoid
valves for a duration of 4.6 seconds if set for small cubes,
5.8 seconds if set for medium cubes or 7.0 seconds if set
for large cubes. Additional 'power on-off' activations are
ignored. If you want to re-run the test you will need to
advance to another test and then go back after you drain
the water out of th
Jan 16, 2017 | Refrigerators
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
The display panel shows OF and now it's not getting cold in either the freezer or frig.
he letters "OF" on the display of your RS267TDRS indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and a numeric reading returns to the display, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Ice maker
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Samsung RB215LASH freezer not cooling ice maker stopped working
Do you see any ice buildup on the back wall of the freezer?
Oct 18, 2012 | Samsung RB215LASH
My model 650 subzero ice maker won't make ice after cleaning out freezer drawer
make sure your ice tray in in the righ position. really important. the tray have to press the ice maker switch. or bad ice maker or bad water valve. also make sure to press the ice maker key. in the display. ONLY IN NEW MODELS
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker not filling with water or making ice- GE pfss6pkwss
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 01, 2009 | Refrigerators
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Frigidaire Gallery GLHS66EJSB Stainless Steel  Side by Side Refrigerator Logo
26 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
