Question about Kitchen Ranges
GE-XL44 - OVEN DOES NOT HEAT ABOVE 100 DEGREES
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Check the temperature probe. It should read 1100 Ohms at room temp.
Post back the results.
Posted on Dec 09, 2012
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
aborcass
  • 2651 Answers
SOURCE: GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Posted on Feb 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile oven won't heat up
Check the temperature sensor with a OHM meter.
It should read 1100 ohms. If not, replace it.
Otherwise make sure the glow bar ignitior is coming on.
Ignitors however can glow and still be bad.
Posted on Feb 21, 2009
  • 14 Answers
SOURCE: I have a GE XL44 gas stove/oven. We did some
gas valve regulator or clogged line
Posted on Sep 03, 2009
FixinFax
  • 3085 Answers
SOURCE: GE profile oven will not heat up past 100 degrees.
You need a new control panel circuit board.
Easy to replace.
Search www.repairclinic.com
Posted on Sep 09, 2009
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
I have a 6 year old GE XL44 Spectra oven that makes a "boom" sound when lit with a smell of gas. I works normal after this happens. A few months back I replaced the glo-bar for the oven, as it would not...
did this problem start when you replaced the ignitor? did you use the right ignitor? was it an exact replacement? did you mount it back in the correct position?
it almost sounds like the ignitor is too far away from the burner????
Jun 07, 2010 | Ovens
Oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44 stove
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL44
Easy to install you just have to remove the racks and the bottom of the oven. Call a local appliance store with the model # and ask for the ignitor.
Sep 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
132 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
