Keyboard on jukebox not working
Digital display shows "0" but does not accept any info from keyboard
  • Audio Player... Master
  • 1,258 Answers
You need to get the service manual and go through the regular steps of troubleshooting. It could be a bad connector or broken solder joint on the keyboard- I would have to see the unit.
Posted on Dec 11, 2012
3 Suggested Answers
  • 5 Answers
SOURCE: The numbers "1" and "0" are not operational on the
If you pull the keyboard apart, there are rubberized membrane keypads above the circuit board. Be sure the board hasn't oxidized. You will find the keypads are all linked together and every 2nd one is not used. Cut out a couple of the spares and put them over the keys that don't work and see if that helps. You may have the same problem with the rubberized keypad on the remote.
Hope this helps.
Mike Graham
Posted on Jan 09, 2011
  • 11800 Answers
SOURCE: The CD number display is
In the 1015 model - the one in the picture, the error 8 signifies that the controller of the player is no longer communicating with the cd mechanism: either the mechanism has failed and it will have to be replaced or the controller has a defect in itself.
The only way to fix that is to open the unit, test and diagnose it and replace the failed part. That is a job that only a well qualified personnel should do - contact Wurlitzer here
http://www.gibson.com/Products/Wurlitzer/About/ContactUs/
to obtain the data on the closest certified repair shop. Beware, the repair will be expensive, over $500.
Posted on Mar 12, 2011
How do I set my rowe r89 jukebox to free play
. Open up jukebox and slide SERVICE SWITCH to SERVICE
2. On Keyboard, Press and HOLD IN POPULAR button and then type "000".
3. Display will now show three vertical lines.
4. Type in "27", then type in "255".
5. Press Popular to lock it in.
6. Slide service switch back to On. The display will now read "255 selections remaining"
Turning off the AUTO PLAY feature:
1. Follow steps 1 to three above
2. Type in "32", then type in "0".
3. Press Popular to lock it in.
4. Slide service Switch back to On.
When you first turn your jukebox on, you will always get some sort of Error reading. This usually involves the Bill acceptor...and you can ignore this message!
Aug 30, 2016 | Audio Players & Recorders
Tip
Sony Ericsson Secret Code
<span><br />IMEI number: * # 0 6 #<br /><br />Software version: &gt; * &lt; &lt; * &lt; *<br /><br />Default Language: &lt; 0 0 0 0 &gt;<br /><br />Enter to phone menu without SimCard - after Wrong PIN: press NO: * * 0 4 * 0 0 0 0 * 0 0 0 0 * 0 0 0 0 #<br /><br />Information about SIMLOCK: &lt; * * &lt;<br /><br />Sony Ericsson Secret Menu: -&gt; * &lt;- &lt;- * &lt;- *<br /><br />(-&gt; means press joystick, arrow keys or jogdial to the right and &lt;- means left.)<br /><br />You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels.<br /><br />You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests)<br /><br />IMEI Number: *#06#<br /><br />Lockstatus: &lt;- * * &lt;-<br /><br />Shortcut to last dialed numbers: 0#<br /><br />Shortcut to sim numbers: On main menu type a number and press #<br /><br />If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press &lt; 0000 &gt; . &lt; stands for left arrow button or joystick and &gt; stands for right arrow button or joystick.<br /><br />note! Try these codes at your own risk! We don't accept any complaints. Some of these codes may not work in your mobiles.</span>
on Jul 11, 2011 | Cell Phones
Hope this helps.
Mike Graham
Dec 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
My laptop is desll vostro 1510. Sometimes its keyboard status light blinks and sometime remains on all the time. When the light blinks or remains on, the keyboard does not work properly. for example if I...
It is very possible that a fluid (water, moisture, coffee, anything) might have poured into the keyboard and now affecting it. Unfortunately, these keyboards are rarely repaired, but instead replaced. Go to your dealers shop to discuss replacement of your Dell Vostro Keyboard.
Dec 14, 2010 | Dell Vostro 1510 Laptop
I have a zd 7140us from HP my keyboard is messed up. When I press certain keys it opens other thngs. For example: if I press key "w" key "8" or ""u" the window...
if the keyboard is fine and you checked on other computer then it shows that the application you are working has gone corrupt, try to re-install OS and application software.
Also try to check with USB/External Keyboard..
Nov 24, 2010 | HP Pavilion ZD7140US Notebook
Not showing charater info
Make sure that you have the latest drivers from the manufacturer.
May 16, 2009 | Logitech G15 Gaming Keyboard
This mb will not accept keyboards
if the keyboard is working fine with other pc's except this motherboard i suggest you to enter the Bios setup by pressing the F2 or Del key before the system boots and set the option Halt On in the Bios setup to----> All error ,but Keyboard
May 08, 2009 | Computers & Internet
I have a 1971 seeburg firestar jukebox - the zero (0) does not seem to work when you punch in the 3 numbers for the selection - so none of my selections that have zero in it do not play - also I do not...
Same key that operates the locks on the sides unlocks the top, but top might be sticky. Push down on it.
Order keys if you don't have them. It's key F291. GOOD locksmith can make it or order one off eBay.
Your jukebox is a USC2. Use that model number as a reference.
Keypad "0" contacts are probably dirty or broken, or the connectors to the keyboard or black and gray boxes might be loose or need cleaning. Circuit board might be dirty (YES! This is a common Seeburg issue). To clean it of check for broken contacts on the "0" key, you'll have to remove it and open it up. Putting it back together can be tricky. Be patient.
Worst case, you can install a replacement keyboard.
If you have someone come out, be SURE to have them give the jukebox a good lubrication. Seeburgs are complicated machines and need periodic lubrication.
Also, buy a manual. Jukebox repairmen don't usually have the manuals for your jukebox. Too many.
Mar 07, 2009 | Audio Players & Recorders
51 people viewed this question
 Grubhead
Grubhead
