Question about Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top Load Washer with Precision
I think my washer was off balance drained, but did not start afterwards washer will start and start sensing then nothinf
I was washing when I went back clothes had not spinned tried to rinse and spin. After that I took all clother out and added another load the lid lock locked and start sensing after it turned off and back on it tried sensing and then the lid lock started flashing
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 08, 2012
ZJLimited
  • 17970 Answers
SOURCE: My Cabrio washer stops at
Some error code there? This may sound strange but give it a try. Unplug the electric. Leave unplugged 2 or 3 minutes, then plug it back in. This allows the controls to reset. It worked alot cases.
Inicially I could think in some drain problem, check hose for any clogged or obstruction there, try to jump voltage to the pumo to confirm if this device is working. If this dont solve it, you will need to check timer; in this link could finr some tip test: applianceaid.com/direct.html#burnt_timer
Visit this site to identify some parts replacement that you could need: partsearch/model.aspx?model_id=5152465&diagram
If you are not sure about how do it this job, or your machine is even under warranty, call the technician service.
Hope this helps.
Posted on Jun 24, 2011
watugot
  • 290 Answers
SOURCE: whirlpool gold top load washer (7 months old) won't agitate or spin
It sounds like the motor drive coupler has broken. This means the motor is no longer turning the gearcase, but it is turning the pump. It will be repaired under warranty if it is only 7 months old. You should have a full one year warranty on the washer. If not, he can probably fix it, but it will need a new coupler. He can tilt the machine back and see the coupler between the motor and transmission from underneath. I can walk you through replacing it if you want, but I wouldn't recommend it if it is still under warranty. There could possibly be something more major wrong that has caused it to break and some of the factory servicers are real picky about customers working on a machine under warranty. If you need it running tonight, he may be in trouble.
Post back if you need further help or have more questions.
Thanks/mike
Posted on Oct 21, 2007
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
  • 98 Answers
SOURCE: Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
Posted on Oct 12, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
Front load washer, try to spin, but stops altogether and want wash it fills up but want wash
Make sure that you don't over load the washer. As it starts to spin back and forth it is sensing the load balance as the clothes fall back and forth. If it doesn't sense a balanced load because the clothes can't fall back and forth it will not start the wash process. Refuse your load and try again.
Oct 16, 2013 | Frigidaire GLTF2940ES Front Load Washer
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
My daughter has a new Whirlpool WTW4800XQ0, it takes the machine about 3 hours to go through the cycle. Okay this being said, when it gets to the spin cycle, it doesn't, she is having to pull the...
does it drain water, seems like it's gonna spin then starts filling up again? if this is what's happening it mean the washer is sensing that the load isn't balanced and it fill back up to move the clothes around and tries again, it will keep doing this untill it senses a balance of weight in the drum. if she tries moving the clothes around herself before it done draining she maybe able to keep it from doing this
Aug 05, 2011 | Whirlpool WTW4800XQ Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    Matyag Atlantis washer didn't drain
    it could be a bad timer on the machine which tells it to change cycles i had the same problem and had to call them to come fix it. if this part is bad then it will go through asll cycles and never change cycles does that make sense?
    Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
    One minute left
    be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
    Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
    Whirlpool Washer LSQ9645KQ0
    The washer has the sound both times but not all the time. I THINK we found all the pieces but now that you mentioned it, perhaps not. Are you thinking there may be a piece lodged somewhere and making that noise?
    di_marie60
    Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Door on washer will not open
    Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
    Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top Load Washer with Precision Logo
    410 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
