Question about Onkyo Audio Players & Recorders
Remotely controling the B speaker volume on an older (TS-SV545) Onkyo receiver.
I'd like to install a set of B speakers in an adjacent room to my older Onkyo receiver (TX-SV545). Per the instruction manual, the receiver has a MRX jack where you could plug in an HR-10 Remote Sensor to control the receiver from another room. I can't find the HR-10 any longer. Is there anything either like the HR-10 or a hard-wired panel where I can control the B speaker volume from another room?
3 Suggested Answers
  • 1126 Answers
SOURCE: Is there any way to program my Star Choice URC550
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=starchoice
This is the only model that I could find. Codes are in the back of user guide. Hope this helps.
Posted on Aug 23, 2009
SOURCE: Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
Posted on Feb 22, 2011
I have a velodyne f-1200r how do I hook up to other speakers
The simplest way is to connect both the left and right channel speaker wires from your amp or receiver into the speaker wire connections on the back of the sub labeled "From Amplifier"
Then connect speaker wires from the adjacent terminals labeled "To Speakers"
What you are essentially doing now is using the internal crossover of the subwoofer where you determine at what frequency the sub begins to blend with the other speakers.
This is done with the Crossover knob just above the speaker wire connections.
Whatever you have this set to, the main volume will now raise and lower the volume of the sub and main speaker together but you can still make the sub louder or softer as compared to the main speakers by using the subs volume control.
Defeat all tone controls on your preamp or receiver and use only the crossover knob and sub volume until you achieve a seamless blend where you cannot tell where the sub is and it is an extension of the speakers from where you will be sitting.
TIP:
DO not evaluate from the sub itself because the room shape and acoustics are drastically different everywhere ESPECIALLY when you are dealing with bass frequencies.
Can I assume you know how to set this?
May 31, 2014 | Audio Players & Recorders
I have 2 qustions?
my guess is that the yamaha has pre-amp outs, most yamaha stuff does, and that is the one you should be using for the main, and hooking up to the onkyo, and letting the yamaha be your zone controler, and the onkyo be your remote amp for your second zone (if your onkyo had pre-amp outs it would work how your trying to do it, but it dont) so exchange there places, and run a pre amp out to any input of your onkyo, and you'll have total volume control of your outside speakers
Jul 28, 2013 | Onkyo Audio Players & Recorders
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
Onkyo 545 one channel don't work
Use headphones or Computer Speakers
and plug in to your headphones jack.
If the audio is present on both channel , check your speaker system
or the jack circuits.
If symptoms are the same, follow the troubleshooting on the link
above.
Oct 09, 2012 | Onkyo TX-SV545 Receiver
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Apr 09, 2011 | Onkyo TX-910 Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
I have a Bose Accumass 6 system connected to an Onkyo amp running as a entertainment system on our boat. The quality is sufficient for what we need. The amp (a TX-DX575) has A&B speaker switches for a...
two 8 ohm speakers in parallel is 4 ohms.
if series 16 ohms.a high resistance will just produce less power.
too low a number can activate the speaker protect,or blow the amp.
radio shack sell wall mounted speaker controls,but 5 watt max.
the best thing is to run 2 amplifiers.one for in ,2 for out
speaker a and b on the amp parallel the speakers.
if you run 2 sets of 4ohm speakers,the amplifier load will be 2 ohms,and overheat the amp.4 8 ohm speakers,gives a 4 ohm load
May 09, 2009 | Onkyo TX-DS575 Receiver
How do I connect my bose 901 active equalizer to a onkyo tx-sr506
AV receivers are notoriously incompatable for Bose 901s. The problem is the EQ charges the entire system and could damage the surround processor. Some higher end AV receivers, including some of the newer Onkyo models have pre out power in inputs on main or all seven channels.which you could install your EQ directly between pre amp & power amp without damaging processor. You can also add a two-channel amplifier to the pre out jacks front channels and use your recever's remote to control volume.
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
May 21, 2008 | Onkyo TX-SR605 Receiver
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
52 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
