Question about Kenmore 24032\24036 Top Load Washer
My Kenmore 80 series is spinning wildly inside and at times won't even spin or agitate. Getting the humming sound
. Push and pull on the start stop and it would eventually start up. Also it started sparking and sending smoke up from behind the machine but I checked out the plug all the way til it enters the machine , no cuts or signs of arcing. I'm a fairly good DIYer with electrical experiece and would wanna give it a shot before I spend service money or throw it away.....any help is appreciated.
  • Marvin Dec 08, 2012
    I should say its at least 6 years old and now it bangs and spins, agitates wildly, to the point where I t made the loop base pop off and now flaps as well.
  • 1028 Answers
SOURCE: kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Posted on May 01, 2008
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
SOURCE: Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Posted on Dec 11, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Posted on Feb 22, 2009
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore washer won't spin or agitate. Sounds like it wants to but can't.
Does the washer fill with water then stop and hum? The problem may be in the timer or processor or it could be the switch that confirms the lid or door is closed.
May 30, 2012 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
