Question about Manitowoc Series Q 210 Self Contained Undercounter Air Cooled Ice Machine Half Dice
Manitowoc ice machine control board blows 7 amp fuse
3 Suggested Answers
  • 112 Answers
SOURCE: Manitowoc Ice machine only makes 2/3 bin of Ice
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Posted on Jan 04, 2011
  • 22 Answers
SOURCE: My Manitowoc Ice machine is making ice slowly and
You're bridge thickness is set to high, lower the bridge on the sensor located when you open the front door behind the water curtain on the top. If the sensor is scaled badly replace it.
Posted on Feb 14, 2011
My Manitowoc Ice machine will not produce ice. The harvest light is on and it will run through the clean cycle
Hi, contact your local appliance repair facility, you may have problems with the control board, the ice level sensors or curtain.
Nov 26, 2017 | Manitowoc Kitchen Appliances - Others
I HAVE A MANITOWOC QM30A ICE MACHINE. WILL THE LIQUID LINE THERMISTOR CAUSE IT TO RUN BUT NOT MAKE ICE?
Liquid line sensor on ice machines in general is used in conjunction with the control boards to determine defrost and harvest cycles. You could measure the line temp and chech the resistance of the sensor to check it.
Betabass
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jerry_8a145f1328fa119f
Sep 07, 2016 | Manitowoc QM30A Self Contained 65Lb...
Ice machine manitowoc gets stuck when full of ice why?
Service Literature Downloads - Manitowoc Ice
www.manitowocice.com/minisite/service/servicedownloads
Manitowoc Ice has a complete library of service documentation offered in two different formats. First, Interactive Electronic Document Catalog (EDC). Second .
Aug 25, 2015 | Kitchen Appliances - Others
How do i change control board of my ice machine become my father take off the control board
First do you have the new control board ? If not then you need to get with a supply house that sales Manitowoc parts. Now if you have a board or have bought one the here goes. Looking at left top corner of board there is a AC Line voltage electrical plug ( numbers marked on wires ) There is only one that will plug into it. Under that there is a main fuse (7A) then under that is a Automatic Cleaning system (AUCS) accessory plug you wont use it. Under that is the ice thickness probe (3/16 ) connection Marker 1C check water thickness probe and follow wire back to end and plug it to 1C. Now under that one is a spade marked 1F that is the Water level probe terminal go to water level switch in sump tray and find the wire that goes to it and put on 1F. Under water level spade is another spade marked 1G this on is not used on this model. At the left side bottom of board is another plug in this is the DC low voltage electrical plug the numbers are marked on the wires that plug into it there is only one plug that will plug into it.
Jan 20, 2015 | Manitowoc QY-0134A - Ice Machine, Cuber,...
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
Manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
Ice machine starts on harvest mode and will not go on to production
you will have to find the main board unplug the connector for about a mintue plug back in. This should reset unit
Aug 05, 2009 | Manitowoc MAN-CVD2075 Condenser Unit...
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Manitowoc 210 ice maker
The thickness control (Im not sure if its like the bigger models) isa plastic piece that has 1 or 2 metal prongs that as the ise is frozen to the evap plate the water trickels closer to these probes. eventually commin gin to contact with the probe and allowing the board to "see" that the ise is ready for harvest. Perhaps this is set too close?
Or the machine may need a good cleaning. DO NOT USE LIMEAWAY on manitowoc. It has a nickle coating on the evap plate and the cleaner has to have inhibitors in it to keep the nickle plating from flaking off.
From your genmeral information these are a general idea of the 1st 2 things that can cause your problem.
Please ratem me as high as you can and let me know if you have tried anything and the results or if you have more information to add.
Mar 29, 2009 | Manitowoc Koolaire Undercounter Freezer...
Manitowoc Series Q 210 Self Contained Undercounter Air Cooled Ice Machine Half Dice Logo
188 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
George Merkley
George Merkley
jasbo
jasbo
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
