Question about Samsung LN-S2738D 27 in. HDTV LCD Television
Samsung LN-S2738D Screen Flicker
When I turn on my LN-S2738D Samsung HDTV it starts off in total blackness, then slowly starts flickering a picture. Usually this lasts for 15 minutes (or longer if the tv has been used in the past few days) .. until the flickering is gone. I've read about the power supply problems with other Samsung models, but mine is from 2007 which is before the 'class action' suit for 46 and 55 inch model tvs. The solution for those models was to clip a certain jumper on the power supply. Is a similar fix possible with my unit? Or, could my capacitors be going bad? Or, is it something else? Thanks in advance for any help or guidance.
  • 11 Answers
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
  • 4090 Answers
SOURCE: Samsung ln t4665f : Power Light On , No Picture : Clicking Sound
there is a soloenoid type switch that fires the TV up this has failoed. its like a neon or fluoresecent tube that has a faulty starter switch light tries and tries but never quite makes it when it does get going it has that purple smear in the tube. that is the simple explanation for your problem. part is about $60 labor is unkinown as i am not in USA but looking at some of the rip off charges I am glad i dont have the bill
Posted on Aug 20, 2009
  • 610 Answers
SOURCE: LE46M86BD SAMSUNG LCD Picture issues (turning off after 5 secs)
you will need a tech to isolate the fault. could be power supply board or the main board but I suspect it is the lcd panel itself that is failing.
Posted on Oct 30, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My TV will flicker at times and go completly black for a period. I unplugged everything and let it sit for about 12 hours and the TV worked fine the next day. The following day the TV again flickered and...
The screen flicker than go blank,does it still have power to the tv set?Yes,than this cause only can be causes by only 2 boards in the tv can causes this problems,if tv power still stable for the set.The T-CON board it shorting out and dying for this problems to happen or worst case causes the Main board tv Tuner signal board it dying.The T-CON board the priced it is cheaper and could cause this problems too.Tries change this T-CON board first,see what happen.This board T-CON board sit at the bottom in the middle of the LCD screen panel to decodes pictures pixel before it go onto the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jul 27, 2011 | Samsung LN-T4071F 40 in. LCD HDTV
Samsung 27" lcd tv picture goes black, still have
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!(*&^%
Mar 19, 2011 | Samsung LN-S2738D 27 in. HDTV LCD...
Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
Oct 15, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung 32" LCD tv, No picture with audio
i will first resolder all ic`s and connections,especiall on the crt board,clean around the flyback at the abl circuits,check for open or changed valued resisters in abl circuit and the video b+ on the crt board (usually 165-200 volts) check also the screen voltage (G2) volts,should be around 250 - 400 volts.
Sep 18, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung lcd hdtv ... no video (black screen)
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 30, 2017 | Samsung LN-S2738D 27 in. HDTV LCD...
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-S2738D 27 in. HDTV LCD Television Logo
142 people viewed this question
Jerry Greenberg
Jerry Greenberg
