Question about Pioneer VSX-456 Receiver
My VSX-456 just quit working - the standby light works so it gets power but the menu panel doesnt light up - guess after all the years I should replace it - any suggestions?
Joelpogi
SOURCE: i have a pioneer vsx-501. I can't get it to turn
have you fixed it already?
I have the same receiver with the same problem as yours.
I found the fault in the voltage selector rotary switch. I'm refering to the round voltage selector switch not the other one, because you'll notice that there are 2 voltage selector switches at the back. The lock was broken so it couldn't switch the primary terminals of the main transformer.
Basically this amp has 2 power transformer, the small standby traffo and the large main traffo.
Try to press that round switch and press the front panel power switch. If it goes ON, then fix the center lock of that round switch.
Hope it helps.
Joel Herrera
Philippines
Posted on Nov 19, 2009
SOURCE: pioneer vsx-456
I have um Acquitance Groundbreaking VSX -456 as you I turn on appears Poweroff and he turns off automatically if he may go feasible ma ajudem,pois did not what to do. thank you Awaiting recurrence for its email: domingosdsm@globo.com
Posted on Jun 08, 2008
SOURCE: standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Posted on Oct 14, 2008
petraman7
  • 1175 Answers
SOURCE: VSX-D409 - Standby Light - Does not Power On
Hi...
Make sure all the speakers are connected properly at BOTH ends.
If still **** then seek a service tech
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: the power standby light doesn t go on when my my
that is becaus eit should only come on when on stadby
Posted on Apr 02, 2009
My pioneer vsx 54 tx is in a blinking standby mode. The blinking light will not go off and the unit will not power on. What do I do?
http://www.retrevo.com/support/Pioneer-VSX-54TX-Receivers-manual/id/385dj996/t/2/
Or maybe something is obstructing the rear panel ventilation device (or it has failed). Page 84
I had a problem recently after a power outage where both my receiver and an external amp would not power up until I unplugged them from the wall for a moment first.
Jul 19, 2011 | Pioneer VSX-54TX Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioner VSX-456
weak standby power supply. locate those capacitors on the standby power supply .
Feb 23, 2010 | Audio Players & Recorders
Blinking Standby Light on receiver, no power
Unplug from power socket for few hours,most likely had a surge from storm and destroyed,either way will need to be serviced to evaluate damage if power trick does not work
Jan 05, 2009 | Pioneer VSX-915-K 7.1 Channels Receiver
Standby light on pioneer vsx-d308 receiver
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Receiver won't turn on. All I got is the flashing light.
Try pushing these buttons at the same timwe for a few seconds:
Advanced Surround + Enter..
'Advaned Surround' will be found in the front panel and 'Return' near the multi-jog dial.
cheers
Mohammed
Mar 09, 2008 | Pioneer VSX-D712 Receiver
Pioneer vsx-456
Nov 20, 2007 | Pioneer VSX-456 Receiver
Receiver just blinks standby will not power on
I have been so bummed, days now I have tried to get my Pioneer receiver to power on from standby with no luck.  We now have our receiver back, the same solution worked for us. Be sure to push the buttons on the receiver unit not the remote.  Thank You! Thank You!
Jan 30, 2007 | Pioneer VSX-D812 Receiver
173 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
