Question about LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs
How do i change door lock switch on lg wm2077cw
I need to replace lock switch. how difficult is it to remove front panel
    Top Expert:
  • LG Master
  • 9,472 Answers
See if this video helps you.
Posted on Dec 08, 2012
aborcass
  • 2651 Answers
SOURCE: LG TROMM Model WM2077CW-mildew on rubber
First and foremost you MUST use an HE detergent, HE(high efficency) is design specifically for fontloading machines.. and use little amounts of it, 2-3 tablespoons is all that is required to clean a full tub of clothing.
Jusst using less of regular detergent is not the same as using correct soap. the moldy smell and black filth when the front bellow is pulled back is actually residual detegent not being disovled in normal operation , all front loading washers are experiencing this issue, there is a new product on the market to help combat this problem and for the 1-2 months ive been reccomending no one has told me that it hasnt helpd. heres the link www.affresh.com
Posted on Apr 09, 2008
SOURCE: Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Posted on May 01, 2009
  • 56 Answers
SOURCE: LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
Posted on May 27, 2009
taran_2005
  • 10515 Answers
SOURCE: LG washerwon't spin
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 03, 2009
SOURCE: How do you remove the top on a LG WM2077CW front
I can not remove the top cover of my LG WM-2277HW
can somebody tell me how to lift off the top cover. I already
removed the screws from the rear
Posted on Nov 10, 2009
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
How do you remove the front panel on LG model # DLG0452W . I want to replace the igniter glow.
Disconnect the washer from the power source. Use a putty knife blade to release the locks of the top panel. Insert the putty knife blade in the seam between the top panel and the front panel about 2 3/4" from the edges. Push until the locks are released and lift the top panel.
Open the door and remove the 2 screws from the bottom of the door opening. Remove the 2 screws from the upper side of the front panel and pull the front panel out. Disconnect the door switch connector and remove the front panel completely.
Feb 12, 2010 | Washing Machines
LG wm2077cw washing machine: cold water won't shut off.
You probably have a bad cold water valve. Remove the screws ot the top cover after unplugging unit These screws are on the back at the top. Slide the cover back and up. Trace your cold water line to the valve and this is the one that is bad. It is held on by screws from the back. Remove the old and replace with the new.
Jan 24, 2010 | LG WM2077CW Laundry XL Front Load...
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
Mar 06, 2009 | LG WM2077CW XL Front Load Stackable Washer...
My lg front loading washing machine does not start
sounds like you have a faulty door lock and it will not turn on if it cannot lock, you will need to get it replaced. Look around at different repair shops as some charge more than others
Jan 14, 2009 | LG WM-2277HW Front Load Washer
Maytag stackable washer top loader
try replacing entire lid switch assy, come ith new fuse!
Oct 31, 2008 | LG WM2077CW Laundry XL Front Load...
Lg front load washer model wm2077cw
Your board has an built in fuse that cannot be replaced.  You will need to have the control board changed.
Sep 24, 2008 | LG WM2077CW Laundry XL Front Load...
Door lock
if you cannot get to it by just reaching between the rubber rim.
The official way is to take off the top and bottom access panels , 3 screws on each in top rear and on the bottom front, then remove the front control switch panel.
then you can remove the front of the machine.
Feb 27, 2008 | LG WM-1090FHB Front Load Washer
LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs Logo
146 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
