Question about Procom Heating & Cooling
Gas fireplace goes woosh
When gas fireplace is ignited, there is a delay and then it goes woosh
4 Suggested Answers
SOURCE: gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at homeprohandyman@verizon.net
Posted on Feb 23, 2009
johnrodgers1
  • 80 Answers
SOURCE: Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Posted on Feb 06, 2010
espressonist
  • 1711 Answers
SOURCE: I have a gas fireplace
The gas pressure is not stable. Either gas pressure valve is problematic, or the burner orifice is dirty and the pressure out is blocked. You can try to clean the burner orifice first.
Posted on Nov 06, 2010
Delayed ignition in bake setting caused burst of gas in oven
look at the ignitor and possibly replacing it . there should be no delay
Aug 02, 2015 | Kitchen Ranges
Majestic gas fireplace mmodel majestic fireplace 36CDVXTRN will not stay lite after 20 minutes.
If you are able to , open the burner box , the igniter has a thermocouple ( might look like a thick wire that would be in the flame if it were on). If it gets corroded or junked up it will not register the flames presence and will shut off the gas). Take an emory cloth and polish it. Hope it helps.
Feb 05, 2014 | Heating & Cooling
Majestic DVR 36 RN gas fireplace pilot flickers when ignited, eventually gets to full pilot. Ocasionaly burner shuts off, pilot remains on. Also, need owners manual for part numbers. Help.
Does your fireplace have a thermostat connected? If so, that may be why the pilot stays on and the burner goes off. Otherwise, it could be a bad thermopile. If that is the case, I recommend you just replace the entire pilot assembly. It is an older model and manuals can be hard ti find. If you still have trouble, I recommend you contact a local certified gas appliance technician.
Jan 12, 2014 | Majestic Fireplaces Majestic Topaz 20ILDV...
Gas fireplace
replace pilot assembly and pilot generator
Sep 05, 2013 | Pool & Spa
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
My gas fireplace's pilot light is on-but when I turn on the electric switch the fireplace will not light all the time. Sometimes it may take 2-3 minutes before it lights up but then goes out after 30...
I had this exact problem.
Open the glass front. Take a piece of fine steel wool and clean the little metal ends where the flames ignite. Sometimes they just get gummed up. It prevents enough flow from getting through to maintain a flame.
Jan 21, 2018 | Napoleon 36" Zero Clearance Top/Rear Vent...
Hi I have a pitco sg14 fryolator. At the time of firing off main burner there is a false ignition at start of heating cycle of oil in tank and there is a woosh sound that shakes front door so basically the...
for the latest design of pitco frialator, the manufacturer added what they called the self-cleaning burner system.during start-up, ignition is delayed so that dust accumulating in the burner face will be removed once the gas build up on burner chamber ignites, it creates a weak explosion like sound.the next time you hear that during start up, the unit is cleaning its own burner, no need to worry.
Mar 28, 2011 | Pitco Frialator SG14 Deep Fryer
I have a gas fireplace with a wall switch. Every time I turn the switch on there is a 30 or 45 second delay before the excess gas goes up in a fireball and extinguishes the pilot light. Is the gas outputs...
Nov 06, 2010 | Heating & Cooling
FIRE GOES OUT AFTER AWHILE
Hi clean pilot light check out thermocouple might need new one
Nov 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
149 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
