Question about Oster Almond 10 Speed Kitchen Center Mixing Arm Head 51b
My Oster kitchen center is making a scraping noise when I hit the start button. I was using it to grind celery
It was working fine grinding bologna, eggs and then started to grind celery and it started to make a scraping sound
2 Suggested Answers
  • 10 Answers
SOURCE: oster kitchen center 5500-08a
I have not seen this problem with ours yet but if turning up the speed doesn't help (first thought would be the motor's overloading because you're using hard foods in it on a low setting). If it shuts off even under light loads, judging by the manual it's something you need to send it in for. See if there's a service center in the area. These Kitchen Centers aren't made any more and it's unlikely you can fix it yourself.
Posted on May 04, 2011
Cuisinart stand mixer making grinding noise. What is it and are there directions for fixing/replacing it?
inside those mixtures there is grease or oil to keep the gears running smoothly. look on your counter or where it is stored and look for grease or oil. if there is then your best bet is to find a repair shop. ask where you got it from, they should be able to hlp.
Oct 29, 2014 | Cuisinart 5.5-Quart Stand Mixer SM-55-...
Why is kitchenaid blender making loud grinding sound, only with carafe in place?
If there is no noise without the beaker it will not be the motor. The problem is in the shaft & bush that holds the chopping blade. Dismantle, clean & lube it. If that does not fix it replacement of the assemble is the only other solution
Jun 08, 2014 | KitchenAid Blenders
GRINDING COFFEE BEANS
Grinding beans is a personal preference job. The finer the grind, the stronger the flavor. You get more surface area contact with the water. Pulse, don't just hold it on. Pulsing prevents heating up the beans and making the oils bitter.
Feb 03, 2012 | Blendtec Blenders
I have osterizer food grinder( Detouchable) but machine was lost where can i find a replacement for the machine...
If you mean the one that attaches to a Kitchen Center, they are no longer available, eBay or garage sales are your only hope.
http://www.ebay.com/itm/OSTER-REGENCY-KITCHEN-CENTER-MEAT-GRINDER-ACCESSORY-/270805020990
Same with the free-standing models they had.
Sep 12, 2011 | Blenders
My oster blender make a couple whirls, something
hello mam
this can be repaired please take it to a service center.
Sep 13, 2009 | Blenders
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Jun 06, 2009 | Oster 6700 Work Top Blender
Oster kitchen center 5500-08a
Sep 23, 2008 | Oster Blenders
Replace oster kitchen center base drive part
I'am the guy who posted the comment I found out how to do this.
There are 2 possible solutions the 2nd is not pretty, hope the first works for you it didn't for me.
1- The motor must be lock up, by placing a thin screwdriver through the holes in the base into the fan down into the motor,holding the screwdriver, remove the square drive from the top.The part you are trying to remove actually is screwed into a gear in the gear box, you will need a spanner wrench,(sometimes a strong pair of long nose pliers will work, engage the spanner holes,hold the screwdriver ,and try to unsrew it, you may need someone to hold the screwdriver,because it takes a lot of force to loosen it.These are regular threads,and unscew counter clockwise.
2- if #1 doesn't work-this will- but its not so pretty.The motor assembly attached to the gear box will have to be removed,it will come out as one piece
Remove the bottom plate,unplug the white wire from the speed control,and the blue- white wire from the board,also you will have to remove one of the brushes with the white -blk lead.
Now you will have to actually break off of the top plastic(bakelite)by whatever means you dream up (I actually used a small wood chisel to score a line, and crack it) once its cracked, it breaks apart easily.Once thats done turn it over and remove the four screws holding the gear box to the housing you will now be able to remove the gear-box motor assembly.
Remove the 3 screws from the top of the gear box pry the box open,remove the gear with the piece that needs to be replaced,now you need to get the piece unscrewed from the gear.I did this by locking the nurled end into a vise, and very carefully grabing the gear teeth with large channel locks(if you think of a better way thats great)it work for me,but I was very concerned about the gear teeth,you can't slip.
Try the new piece to make sure it sets all the way down to the bottom of the gear(it must or your head will be to high ,and won't lock down)if all is well,make sure everything is greased,and start re-assembly, the new coupler ,and the square drive will be the last 2 pieces assembled from the top, once again locking the motor with a small screwdriver.
Feb 11, 2008 | Blenders
Oster Almond 10 Speed Kitchen Center Mixing Arm Head 51b Logo
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
