Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
My tro bilt model tb320bv gas leaf blower will not run at full th
My troy built model tb320bv gas leaf blower will not run at full throttle. If I keep pumping the priming bulb it will throttle up to normal but when I stop pumping the priming bulb it barely runs. What is wrong and how do I fix it. Repair shops tell me it will cost more than it is worth to have them fix it. Please help.
  • t5vespa May 18, 2009
    I have or had a similar problem. Mine would run and quit with no warning. All the basics were checked. Found no fuel going to the plug, took the carb apart and cleaned it, no help. reassembled it all and it started working then it happened again a while later. Went through the same motions, no help. It always took many pulls to start and had to prime it ten times. I owned other two stroke engines and never had to prime it ten times, five the most. This unit is junk. The problem is that the spark plug is on the bottom of the cylinder and is prone to flooding which leads to hard starting. I reached my end with this unit and slammed it against a concrete wall, came apart in pieces and it made me feel good. Now I will go and buy a real blower from a real company that makes their products in the USA not Mexico like Troybilt does. Troybilt was once a good company but now they stink, no more quality control.
    My solution is do not buy a Troybilt product. JUNK, JUNK and more JUNK!!
    Scholar:
  • 76 Answers
The carburetor may need to be taken apart and cleaned or rebuilt. If you haven't taken one apart before your best bet is to see if you can get an after market carb for it, that would probably be the cheapest way out.
Posted on Jan 14, 2009
My leaf blower starts great but takes a while to warm up thats ok too. but when i run it full throttle after warm up its runs for a few seconds and bogs down and runs very slow then after about 5 min. of...
sounds like a plug problem, pull the plug and check the quality of it, also check the gap. also are you useing the correct gas oil mixture , with fresh gas.
Mar 12, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Engine dies out at full throttle
could be one of two things either a carb kit or need to adjust the jets on the carb if it has two jets then there is a high and a low
Feb 19, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Need carb adtusted
Hold @ full throttle and adjust high (H) screw until she raps out to max RPM, let off, if idle is rough adjust low (L) screw until idle is achieved, You should have it, if not, clean carb and check fuel filter.
Nov 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Tb320bv blower, I can set the choke and start it but it will not run. As soon as the choke pops off during acceleration the blower dies.
This would indicate that you need a new diaphram in the carby not very expensive any mower shop will do for about $30
Jun 25, 2010 | Troy-Bilt Mtd Southwest Tb320bv...
Same model...same problem!
its the carb , have you tried setting the low speed
Aug 30, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy-built TB320BV will not stay running
get a can of carbeurator cleaning spray. get a helper and as one of you runs the thing, the other will give it short bursts of carb cleaning spray right into the air intake, leave the filter off while you do this.
Aug 22, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Starter rope trouble
it might be vapor lock, try taking the spark plug out and giving it a pull
Oct 18, 2008 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
1,673 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
