Question about HP Pavilion a1130n (PX769AA) PC Desktop
HP Pavilion a1130n power button
Power button works intermittently. When it doesn't, a very light tap on the top of the case will put the power to the desktop. Inversely, there are power shutdowns that can occur at any time but the OS will usually boot up immediately on its own. A few times when it didn't I resorted to the tap on the case to get it back on. What is involved here with regards to changing out the switch and is it possible to do that. Problem has been with me for over a year now and is not fun when it shuts down in the middle of something. Nothing gets lost, I just have to start over.
  • HP Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit. If you can get your computer stable enough scroll to bottom toolbar bottom of screen right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs not having enough computer ram can cause memory dumps If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible. You might have a virus or malware. Download at least one of these of course it will depend on your operating system. http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Hope this helps.
Posted on Dec 08, 2012
  • 4 Answers
SOURCE: HP Pavilion a1010n won't start
Make sure there is no dust covering the computer fan. If necessary use the recovery CD or a new Windows XP CD.
Posted on Jan 29, 2009
mrsjill
  • 41 Answers
SOURCE: i have a hp pavilion 513c it wont boot up! the
There are only two ways this can go for you.
One- you need a new power supply
OR
Two, you need a new mother board
You can verify the power supply by checking it on another machine
If the power suppy is good
And you do not hear the bios beep- then you are looking at a new motherboard- I would double check the powersupply first- most stores that sell them will let you check before you buy a new powersupply.
Posted on Mar 26, 2009
  • 27 Answers
SOURCE: Media PC HP 7350n Starts runs for 10 sec or more then powers down
its definately not the motherboard, actually when a ps is about to spoil it starts giving that problem and also, the memory cards are also able to cause this problem too. but first, plz try changing ur ps and see if it works..
Posted on Apr 07, 2009
Combchris
  • 64 Answers
SOURCE: HP Pavilion A520N will not power up. Green light
Which light?? the network light?? Do you get anything when you press the power button if not it is most likely the power supply since the motherborad is still showing power also may be cpu!
Posted on Nov 17, 2009
luke4010
  • 35 Answers
SOURCE: Hp Pavilion a1120n will not power up.
Yes it needs a power supply. You can get a cheep one on eaby or get one off of the HP site
Hope this works,
Luke Wilcox
Posted on Dec 29, 2009
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
Hp laptop doesn't turn on, no lights
From the description it is a motherboard failure, only option is replacement.
Apr 30, 2012 | HP Pavilion dv1010us Notebook
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem it won't boot up, it lights up but nothing else
Does it make a beeping sound when you turn it on? If it does try this:
Turn it off and take the battery out for about 2 minutes. Put the battery back in and press the power button to turn on. Immediately tap the F8 key on your keyboard. This will bring you to the advanced boot options. Choose last known good configuration.
If that doesn't work you may also try choosing system restore in the advanced boot options and follow the instructions. Note that a system restore brings the computer setting back to a previous restore point.
I hope this helps.
Cheers,
Sep 04, 2011 | HP Pavilion dv9000z Notebook
HP Pavilion a767c Desktop blue power light want come on. Have unpluged the power cable and held the power button in for a short peroid of time with not results. Can you help?
Hello Chris, If you turn on your power (may have to toggle the power button behind your computer before pressing the button, worth trying in each position just in case and make sure the power cable has been plugged back in) and your computer doesn't come on at all. If none of your lights come on AND none of your fans come on, then your power supply may have gone bad. If this is the case then you can't even begin to try and diagnose the rest of your PC to see if it's working. You need power to attempt diagnostics on your other components. Another thing to check is to make sure the fuse on that outlet has not blown, if other things are plugged into that exact same outlet, are they receiving power? Also if you have the same standard power cable that you use from your monitor to the power source, maybe try switching it out and using it on your PC to see if it makes a difference. Hopefully this helps you with your problem Chris, have a great day!
May 07, 2011 | HP Pavilion a767c (82916052406) PC Desktop
Hello, My hp pavilion dv2610us will not power up
your motherboard in the laptop has failed... sorry :(
Mar 13, 2011 | HP Pavilion dv2610us Notebook
HP Pavilion a1130n PC Desktop for some reason this machine doesn't want to read my sata drives anymore...i have no other machine to test them on. i pulled out the ps one night...put in a new ps and bam my...
i would try replacing the hard disk drive SATA cable , worth about $5, founjd at any computer store
actually bring the drive with you and ask them to do a courtesy test
Oct 19, 2010 | HP Pavilion a1130n (PX769AA) PC Desktop
HP Pavilion a1130n (PX769AA) PC Desktop Logo
59 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
