Question about Garden
Trying to fix the impeller
So...I took the case off, and found the impellar of my Troy Bilt 320 BV leaf blower had sheared off, and it came right out. now I have the new impellar, but can't figure out how to get the bolt off the shaft to put the new impellar back on. I tried a strap wrench, no dice. I am also trying to be careful and not wreck anything any advice? Foto attached of old impellar and now I need to get bolt off, replace impellar, and then bolt on
  • 1 more comment
  • Jeff Bennett Dec 08, 2012
    Here's the photo of my problem
    so there's the old impellar, now I have to figure out how to get bolt off...the shaft of course spins freely. I tried a strap wrench, no luck.
    I looked at the parts schematic and I took of B11 engine mount plate. I think I need to take off B18 bolt to get the remnants of the old impellar off, and then put on new impellar, and then put in bolt....getting the shaft to stay still is proving challenging. here is the schematic i am going off of: http://www.ereplacementparts.com/troybil...
    President:
  • 1,851 Answers
Take the unit to a mechanic with an air wrench or buy an electric impact wrench.
Gary @ Fix Ya
Posted on Dec 09, 2012
3 Suggested Answers
s_s_m_o_k_i_
  • 162 Answers
SOURCE: replacement suspension for the troy-bilt back pack leaf blower
http://www.troybilt.com/webapp/wcs/stores/servlet/topcategory_10001_14102_-1
Posted on Jul 31, 2009
randyprevost
  • 887 Answers
SOURCE: fix impeller on try bolt leaf blower
...and then what?
Posted on Dec 01, 2012
Which gas line goes to the top of TB 320 BV troy built leaf blower. 41DS320G966 carburetor 753-04338?
I suspect it is the one from the gas filter in the tank. If that doesn't work switch the lines around. Hope this helps. If not let me know if it has a primer bulb or not and I will try to help. Hope this helps.
Nov 20, 2015 | Troy Garden
I put too much oil in my troy bilt 4 stroke leaf blower I started it and it broke instantly can it be repaired or trash it and move on?
what broke on it ?..drain the oil down to the right level and see if it runs., use manufactures specs on how much oil, and set in the right position to check
Sep 18, 2011 | MTD& Troy-Bilt& Suitcase Blower
Troy bilt electric leaf blower will not turn on. model # tb190bv. suspect that it is the switch.
yes i would say your right, check your wiring to, make sure you have no shorts. good luck
Oct 17, 2009 | Troy-Bilt Garden
Troy bilt blower (gas) will not run on full throttle,if I have the choke on will run but as soon as I cut back on choke the machine dies.
I believe you need some carburetor adjustment done or you have some bad gas. The manufacturer's school we have been to this year, told us any fuel over 30 days old is considered bad gas. And in many cases we have found that to be true with the repairs we have had to do.
Good Day.
Oct 07, 2009 | Troy Bilt Tb310qs Gas Blower
Troy bilt tb320bv wont start. only two months old.he cord won't pull out completely like it used to and it won't let me start the thing any longer. It is like something is jammed in the system.
It seems to be a usual problem with troy bilt trimmers and leaf blowers. There should be a half moon piece of keystock that holds the flywheel on,sometimes its known to sheer off. Could also be one of the keepers that hold back the plastic disk for the cord comes loose,it gets in a bind. Either way,you have to open up the case and see whats going on.
Aug 05, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
